VideoHelp.com Forum
    I've searched the net for solutions and haven't found anything. perhaps I'm not describing my prblem correctly.
    Please forgive if this is to much info.
    I have an HP DVD740 Lightscribe - This unit has worked perfectly since I got it last Christmas.
    Recently it stopped recognizing my blank media - I thought I had gotten a bad batch. So I tried a different brand
    1. Maxell DVD-R
    2. Memorex DVD-R
    I use Nero which keeps prompting me for a blank disk even though one is in. I uninstalled Nero and used the Cleantool to make sure it was gone.
    I then installed Imgburn - It states No Media present( not sure of exact verbiage)
    Thinking maybe the drive was bad - I installed a Memorex DVD-Rewriter and it showed the same thing.
    BTW: I upgraded the firmware on both drives.
    If I stick a Blank DVD-R in the Memorex drive - XP gives me the what do you want to do with options for CD recording (Audio CD, etc)
    If I stick a store bought DVD movie in the Memorex drive - The movie starts and plays just fine.
    I have CA Firewall and Virus protection which finds no issues. _ I'm completely lost anyone have any other suggestions on what to look for.
    Steve
    Sound like normal functioning of "Autoplay" in XP to me.
  3. DVD Ninja budz's Avatar
    Check your drive if it's in UDMA MODE, it could be in PIO mode. Also your ide cable maybe failing, buy a new 80 wire ide cable. Lastly it maybe your HP dvd burner is dying a slow death.
    Use the link below to check that your drive is in UDMA MODE.
    http://www.cdrlabs.com/forums/how-en...res-t7625.html
    http://www.cdrlabs.com/forums/proble...ows-t6645.html
  4. Member olyteddy's Avatar
    XP has no native DVD burning support, so that much is normal.. Odd that ImgBurn didn't work though. Might I suggest trying a Verbatim DVD blank?
  5. Member fritzi93's Avatar
    Tried a lens cleaner yet?
    It's possible there is a filter conflict. Follow these instructions:
    http://support.microsoft.com/kb/314060
    You'll probably have to re-install your burning software after deleting the filters. Worth a shot. Resist the urge to install multiple burning programs. :P
    Pull! Bang! Darn!
  6. Member [_chef_]'s Avatar
    Just delete Upper & Lowerfilters if necessary.
    Reinstalling a burnapp is not necessary.
    *** Now that you have read me, do some other things. ***
  1. PAL -> NTSC DVD Writers?
    By tac7 in forum DVD & Blu-ray Writers
    Last Post: 2nd Aug 2010, 21:34
  2. Sony and Optiarc DVD writers
    By anfield7 in forum DVD & Blu-ray Writers
    Last Post: 1st Oct 2009, 22:44
  3. Samsung DVD writers differences (SH-S223Q/BEBD vs SH-S223Q/BEBS)
    By TheWolf1 in forum DVD & Blu-ray Recorders
    Last Post: 11th Aug 2009, 15:34
  4. Better DVD Writers
    By gameroftheuk in forum DVD & Blu-ray Writers
    Last Post: 30th Sep 2007, 13:51
  5. Buying 2 SATA DVD Writers
    By mis3 in forum DVD & Blu-ray Writers
    Last Post: 13th Aug 2007, 22:08
