Thread: 7GB .iso to DVD
    I have a 7-8Gb .iso file on my computer that I want to burn to a 4.7Gb DVD.
    Normally I use dvd shrink for that purpose but it can't handle .iso files. Tried also with dvd decrypter, but the same there it can't compress the file.
    Anyone got a tip?
  2. Disgustipated TooLFooL's Avatar
    you CAN use shrink! click file/open disc image
    I am just a worthless liar,
    I am just an imbecil
    you're absoletely right
    I totaly missed looking inte "file"
  4. Why not try DVd-DL (8.5Gb) works nicely, no quality loss.
    The electronic components of the power part adopted a lot of Rubycons.
  5. AGAINST IDLE SIT nwo's Avatar
    maybe they not have a DL burner
    Thanks I have a dl burner, but the dl discs are more expensive so I usually just extract the movie to not loose quality, some moore favorite moovies can end up on dl discs. Thanks problem solved anyway.
    I wait for the discs to go on sale. Verbatim 6X DL +R usually around $1 - $1.25 per disc in a spool of 20. Usefull for special disc jobs.
