I am putting together a new HTPC and this board has a plastic plug blocking 4 of the 8 pins of the ATX 8 pin power connector. Does this board need only a single plug with the 4 pins or is the plastic blocking the additional 4 need to be removed and the second 4 pin plug installed? The manual shows the plastic piece but also mentions inserting the 8 pin power plug??
Thread: P7N mobo question
It would help if we knew what MB you are using. P7N is a little vague in my book
However, unless I am very much mistaken, if your PSU has only a 4-pin connector then that is what you plug in.
Some PSU's now have 8-pin connectors yet I suspect that 4 pins are detachable to allow connection to a MB with only 4 pins.
If your PSU has an 8-pin connector then I would have thought that you simply remove that cover to connect it. It is there to prevent you pluging in a 4-pin into the wrong place.
DB83, Thanks for the reply! The MB is an MSI board. It is currently populated with a 3.16 core 2 duo and 4 gb ram. The PSU is a 1000 watt unit with a split 12V supply plug. In other words you can connect 2, 4 connector plugs to make the traditional 8 connector config or leave it as 2 4 connector plugs. I believe you are correct about the cover but I didn't know how the core2 gets its power from that connector.
Black Magic Intensity Shuttle with Gigabyte's GA-P55A-UD3 mobo question.
By Nevermore4 in forum CapturingReplies: 4Last Post: 19th Jul 2011, 23:42 -
Mobo dying?
By Poppa_Meth in forum ComputerReplies: 10Last Post: 26th Apr 2011, 05:50 -
rambus mobo question
By slegh in forum ComputerReplies: 8Last Post: 4th Nov 2009, 20:07 -
Any problems with this MOBO ?
By sdsumike619 in forum ComputerReplies: 1Last Post: 28th Nov 2008, 13:57 -
mobo's with HDMI
By Xylob the Destroyer in forum ComputerReplies: 12Last Post: 9th Feb 2008, 12:12
Statistics
Newest guides
Latest tool updates
New media comments
