Hi. I have a Sony DR710UL, external dvd writer. I noticed that all of the last 8 dvd discs burnt has uneven burning, even in safe mode, or slowest burn speed. I had already updated the firmware but still the same problem.
Is my DR710UL kapootssss !!!!
Thanks.
Percy
"uneven burning" --- what should that be??
*** Now that you have read me, do some other things. ***
Your external Sony DR710UL is a rebadged LITEON drive. What brand of dvd media are you using? MEMOREX & TDK ? Those 2 brands are low grade crappy dvd media. Try using VERBATIM dvd media and burn with IMGBURN. If you're using VERBATIM and IMGBURN then try using another USB cable.
Sony Vegas 10.0d with BD3D burning now available
By Cornucopia in forum Latest Video NewsReplies: 4Last Post: 7th May 2011, 15:31 -
I need some serious help with Sony DVD Architect burning
By Selavast in forum Authoring (DVD)Replies: 6Last Post: 22nd Feb 2011, 17:57 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 18th Jul 2010, 23:26 -
Problem! Very uneven audio level throughout my recording.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2008, 21:26 -
WMV file to AVI playable on DVD player (motion is uneven when I try)
By lizzy1e in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2007, 15:13
Statistics
Newest guides
Latest tool updates
New media comments
