VideoHelp.com Forum
    Hi there. I just reinstalled my Windows XP, and put the codecs pointed as the best choice by Gazorgan in this topic:
    http://forum.videohelp.com/topic191700.html
    I can watch the movies with BSplayer.Pro.v1.38.828, but I want to cut some of them into smaller pieces, so I got VirtualDubMod, that previously worked like a charm. Now the problem is that it canīt open most of the files on it. It gives me different errors, like:
    - Error compressing video frame 0: A codec-specific error ocurred. (error code 1)
    - VideoSourceAVI error: bad parameters (8004406a)
    And the one that worked, the new file (splitted) had no sound!
    I really donīt know how to use ffdshow, but I wanted something simple. Maybe a newbie guide to fddshow or something. My previous klcodec315f.exe codec pack worked fine for me, but the post above says I should not use codec packs.
    Thanks.
    open 'vfw configuration' and 'videodecoder configuration' of ffdshow,
    wherever you see xvid as decoder,
    change it to libavcodec.
    also get.
    lame acm http://www.rarewares.org/mp3-lame-dshow-acm.php
    and ac3 acm decompressor.
    use gspot or mediainfo to check files you're having trouble with.
    check yu have a codec setup for what's contained in the media file.
    post a screenshot if you still have trouble
    tripp
    "I'll give you five dollars if you let me throw a rock at you"
  1. Replies: 2
    Last Post: 28th Sep 2010, 09:11
  2. Problem with VirtualDubMod
    By darkdream4 in forum Newbie / General discussions
    Last Post: 4th Feb 2010, 02:41
  3. VirtualDubMod Problem??
    By 3thman in forum Video Conversion
    Last Post: 8th Dec 2009, 11:07
  4. Virtualdubmod problem....
    By aruwin in forum Editing
    Last Post: 20th Sep 2007, 07:41
  5. VirtualDubMod Problem
    By Mitchum22 in forum Audio
    Last Post: 15th Jun 2007, 11:28
