moving you to the ffmpegX forum...
• About your Computer Details: I suppose you meant 2 GHz instead of 2 MHz. Is it Intel or PowerPC? Apple has made quite a few 2 GHz machines with both chipsets. (PowerMac G5 (Tower)/2.0 GHz (Single|Dual); iMac G5/2.0 GHz; Intel iMac/2.0 GHz; Mac Mini/2.0 GHz; Mac Pro/2.0 GHz (Dual Intel Xeon); MacBook/2.0 GHz; MacBook Pro/2.0 GHz.)
• Did you install the corresponding (Intel or PPC) Reallib for ffmpegX?
• When you do a Clip Info (Cmd-I) in RealPlayer, then choose Streams, what codecs (versions) does it list? (E.g. RealVideo 9 for stream 0, RealAudio 8 for stream 1, sometimes also known as RV40 and cook.)
• When you try to Encode in ffmpegX with Open Terminal Window activated, does it give an additional error that may not be listed in the Process Information log? (E.g. Bus error.) That might point to a PPC/Intel mix-up as described in my 2nd point.
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 06:47
Statistics
Newest guides
Latest tool updates
New media comments
