I have just recorded my first solo with the help of few friends. But I am confused about whether I should go for CD Duplication or Replication. Can anyone help me in making the final decision?
All discs that are sold in stores are replicated -- that is, mass-produced at a disc pressing factory. I think most replicators require a minimum order of 1000 discs. If you only want to distribute a few dozen copies to friends, you can have the work duplicated -- that is, burned on a CD-burner, or a rack of several CD burners. It all depends on your expectations for the final output. I suggest you burn a few copies cheaply to gauge the demand for your work. If lots of people are really hot for it, you can send it to a replicator for commercial production.
Good luck.
I would amend that last statement to update that most replicators now have minimum orders for CDs of 300-500 discs (although the cost per disc isn't quite as good).
How "permanent" and "professional" do you want this recording to be? If tops, then go replication, if less so, duplication would be fine. Think also, not just about the pressing, but of the disc printing and packaging...
I worked with these guys in the past - www.hqsduplication.net They're pretty good. I dunno if they still do, but I had them do a VERY short run - 30 disks only.
I discovered this company in San Jose they will do 100 ~ 300 replicated CD (not the duplicated ones) for $320. The quality is as good as the normal big run with full-color offset printing. New Cyberian, http://www.newcyberian.com
I've used those guys before. Pretty decent work.
confuse about streaming plz any expert guide me
By azeemmir in forum Video StreamingReplies: 0Last Post: 9th Jan 2010, 09:22 -
TMPGEnc Products - Confuse?
By niteghost in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2009, 18:12 -
Confuse about HDMI v1.3
By pwangdel in forum DVB / HDTVReplies: 3Last Post: 26th Nov 2007, 20:13 -
Confuse about TV and DVD players resolution
By hanugro in forum DVD & Blu-ray PlayersReplies: 3Last Post: 6th Nov 2006, 13:14 -
I'm Confuse! Too many AVI compression format
By mamushiraz in forum CapturingReplies: 2Last Post: 26th Mar 2002, 10:26
