    Is there any way or any software that can reduce the size of a 5gb vob file???I wanna burn it but my dvd can only burn up to 4.7gb
    I can't live without my computer.
    Rejig can reduce the size of an mpeg file, and may be able to do the same for your VOB if you change the extension to MPG.
    Better idea would be to author correctly, then use DVD Shrink or DVD Rebuilder on the results.
    How did you get a 5GB VOB file ?
    Read my blog here.
