I'm using EditStudio pro 5. When I import VOB files, they import incorrectly, missing alot of frames, scenes etc..... The movie is reduced from like 15 minutes to 7 minutes.
Any help greatly appreciated.
Thread: EditStudio Pro 5
you might try updating to the latest version, 6.0.5
Where do the VOBs come from ?
If they come from commercial discs, how did you rip them ?
If the movies are not encrypted, I drag the Video_TS folder to my desktop. If I just need a certain part of a movie, I open the Video_TS folder, drag vob files to desktop. If encrypted I used dvd decrypter.
Nevermind - Virtualdub works. Needed to cut out commercials.
DVD Decrypter will produce corrupt VOBs on many newer discs simply because it no longer handles the latest copy protection. You should serious consider using DVDFab HD Decrypter for ripping commercial discs.
Thanks gunslinger, I use DVD fab too. Don't have any issues with vob files, just not able to edit with EditStudio pro. The program has some type of file size limitations on vob files.
Editstudio Pro 6: Effects problem
By Sillyname in forum EditingReplies: 0Last Post: 14th Aug 2010, 19:59 -
EditStudio 6 PRO - Video editing
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 24th Oct 2009, 14:21 -
EditStudio PRO version 6
By Mariot in forum Latest Video NewsReplies: 1Last Post: 24th Mar 2008, 22:43 -
EditStudio pro users
By Illusionist in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 17:52 -
editstudio 5 - now from mediachance, anyone using it?
By aedipuss in forum EditingReplies: 5Last Post: 14th Feb 2008, 15:46
