Just bought my first LCD HDTV, it was refurbished(What? It was over $140 LESS than buying new! As long as it worked....).
Tv works/looks perfectly fine except for a tiny little red dot near the middle of the screen.
I believe I've heard of various ways other people were able to fix this, but don't know any as i've never had this problem before(only other LCD display i own is my laptop screen).
Any suggestions would be GREATLY appreciated.
Results 1 to 10 of 10
probably not, as it may be the reason it was returned in the first place. if they sent it out again with a dead pixel as a refurb, you are most likely stuck with it.
if you google fix dead pixel and try the "fixes" and they don't work.... you saved some cash in exchange for a defective screen. -
return the LCD TV if you're able to. just my 2 cents!
you can try massaging it...but it often doesn't work
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie -
Although dead pixels on LCD monitors are now rare, they're still occasionally there especially on no-name ones. Any brand have policies on how many dead pixels have to be present before some warranty period is up then it considers them defective. This has to be noted because often, when even minutely inspecting an LCD monitor at the moment of sale with no obvious dead pixels, that doesn't guarantee it will remain that way when hauled home and used for a specified period.
What you don't know won't hurt you.
Until it hurts you. Then you know. -
I FIXED it!!!! :P :P
I looked up various sites and tried some stuff but it did not work. Finally i did the screen thingy here:
http://www.killdeadpixel.com/
However after leaving that gif over the spot where the stuck pixel was for about 6 hours, NOTHING happened. In the end, i tried positioning it back over the spot where the stuck Red pixel was, and pressing the area a bit hard with my thumb(not TOO hard), and then removing it.
And it went away! Yay. Something about the liquid in the LCD display not getting around to every pixel, and by putting that square animated gif to "stimulate" the pixel area+pressing down with my thumb & removing, got it to function right.
Not sure but i guess thats the gist of it. Anyway the tiny red dot area, which was a stuck red colored pixel by the way and not a dead pixel, is now gone and the screen appears to be functioning properly.
This was a refurbished, Polaroid 19" LCD HDTV for $200, bought from this site:
http://www.recoupit.com/Shop/Control/Product/fp/vpid/5469171/vpcsid/0/SFV/31197
The same Tv would've cost me about $330 at my local wal-mart, so i figured it was worth a try for the money saved. As long as it continues to work fine from now on!
Thanks for the report. It's good to know that sometimes works.Originally Posted by [url=http://www.videohelp.com/tools/SUPER
it probably didn't have anything to do with killdeadpixel...
I think it did. Because i tried rubbing/massaging the area before, nothing happened.Originally Posted by zoobie
After i placed the killdeadpixel gif over the area, and just pressed down a bit on that area of the screen and released, then it went away and is still working fine.
dot (pixel) pitch and resolution for a LCD monitor - accessibility question
By moniia in forum Newbie / General discussionsReplies: 5Last Post: 19th Feb 2011, 15:18 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
Dell said a dead pixel is normal
By moviegeek71 in forum ComputerReplies: 42Last Post: 21st Jun 2008, 00:53 -
Bad Pixel. What comes next?
By videobread in forum ComputerReplies: 5Last Post: 8th Mar 2008, 21:07 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / HDTVReplies: 3Last Post: 25th Sep 2007, 12:29
