VideoHelp.com Forum
  1. Member victoriabears's Avatar
    I am just making sure that I am not going mad, I inser the dvd , press play and the motion looks like the people are moving like stick figures, then I pause and play and it corrects but does re-occur sometimes.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I can't advise you whether you are going mad or not.
    But describe how you captured and processed the VHS to get to a DVD, the steps and programs and hardware used. Maybe there's a clue there. And secondly, can you post or link a ten second or so clip from the file that shows the problem? Less than 6MB here, please.
    Meanwhile, maybe one of our members has ran into this problem before and can assist.
  3. Member victoriabears's Avatar
    sorry, did not really state my question, which is "Why would it play fine for a few minutes then "revert" to the stick figure syndrome.
    I used a simple vcr to dvd recorder, but would have thought if I needed a TBC that it would be constant?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Just a guess, but the player may be trying to read the disc and skipping frames to keep up. Maybe it's a disc problem? Try a different brand of DVD media? I've seen similar problems with computer software players where pausing lets the buffer refill, but not with DVD players. Maybe too high a bitrate, but that seems unlikely from a DVR?
    You could put the disc in a computer and scan it for errors with something like Nero DiscSpeed or check one of the VOBS with Gspot for the bitrate or anything else that seems odd. Lastly, have you tried other players? If it works on them, then your DVD media may be questionable.
  1. Replies: 0
    Last Post: 12th Apr 2011, 22:34
  2. VHS-->DVD, "action scenes" and bad sources
    By Jdrive in forum Capturing
    Last Post: 13th Oct 2010, 00:09
  3. "Jitter" film playback effect
    By Mylo in forum Newbie / General discussions
    Last Post: 13th Jul 2009, 12:15
  4. Replies: 9
    Last Post: 8th Feb 2008, 16:02
  5. What DVD Recorder Corrects Tape Jitter?
    By deuce8pro in forum Restoration
    Last Post: 21st Sep 2007, 22:52
