What's the best method to create a high quality FLV from a mpeg-2 source or wmv? Any help on this would be greatly appreciated. I've tried doing it with On2 VP6 in After Effects with a bitrate of 1000 but it's still not up to the quality I would like.
What resolution/frame size are you using?
Give us more information about your source, is it interlaced? what resolution/frame size? etc?
I use flash professional and get goody quality.
The resolution is 664x550 source is deinterlaced. these are some fast motion trailers so I need them to be as smooth as possible and as high quality as possible.
If 1000 kbps isn't enough, go higher. Bigger frames, higher frame rates, more detail, brighter pictures, more action, smoke, fog, fire, white-water, noise, anything that causes large areas to change from frame to frame, all require higher bitrates.
Depending on the server software (I think), you can distribute flash using h264/AVC. It would take some work, but it's do-able:
http://somestuff.org/flashAVC/flvpla...e-x640y368.mp4
Encoding parameters below the video
that is perfect soopafresh what programs are needed and would it be a problem if they need to be flv?
Doesn't Adobe recommend using .mp4 instead of .flv now for h.264?
create high quality dvd
By happyjays123 in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2011, 21:12 -
MP4 or FLV High Quality Videos
By gonwk in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2011, 12:51 -
High Quality FLV with metadata for pseudostreaming
By misterio in forum LinuxReplies: 21Last Post: 22nd May 2009, 00:38 -
AVI(w/ High Quality) to FLV issue
By btmdan in forum Video ConversionReplies: 10Last Post: 8th Aug 2008, 10:35 -
Converting from flv to high quality video format
By venus in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 13:47
