I had a quick question. I just bought myself the latest LG Blu-ray burner, and a bunch of single layer BD-R's.
I have on my computer a bunch of PS3 compliant AVCHD discs. I was wondering if there was any way/program that would allow me to take the M2TS files, after I extract them with tsmuxer, and re-author them into a blu-ray disc together. The files are all 1920/1080 and are encoded for playback on the PS3 so I cant imagine why it would not work. I just dont want to waste a $10 BD-R doing the wrong thing.
Any Help would be appreciated.
Btw- I'm not looking for anything fancy like menus, just one title after the other would do fine. And, I dont wish to just put the M2TS's in a data formated BD-R, I want it to be in the BDMV format.
Thanks,
Huck
If you do not care about menu etc, you could do this:
Use NERO Burning ROM DVD-ROM(UDF) choice, use the UDF tab to select UDF2.50
then simply drag all the xxxx.m2ts files to the compilation pane
and burn it.
Please try this test first using a DVD+R or some inexpensive disc before you do try BD-R so
you do not end up wasting the expensive BD-R.
I think it should do the job.
I understand I can do that. Thats why I specifically said, is there a way to accomplish this, *not* merely making a data Blu-ray compilation. I wish to make a compliant BDMV, not just a data disc with a bunch of M2TS files on it.
Thanks, but, Anyone else?
So try with tsmuxer and create a Bluray structured disc....
http://www.afterdawn.com/guides/arch...nd_blu-ray.cfm
Or read this,
http://club.cdfreaks.com/f142/backup...bluray-208395/"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
ps3 blu ray not working
By joeyg720 in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2011, 04:47 -
AVCHD vs. Blu-ray
By coody in forum Authoring (Blu-ray)Replies: 5Last Post: 25th Aug 2010, 20:58 -
Blu Ray vs AVCHD?
By kelvin1704 in forum Newbie / General discussionsReplies: 32Last Post: 18th Jun 2008, 10:59 -
blu ray on PS3
By kirstyholtkamp in forum Blu-ray RippingReplies: 7Last Post: 2nd May 2008, 16:20
Statistics
Newest guides
Latest tool updates
New media comments
