hi guyz
i wanna make a dvd from downloaded movie, so they are of .avi format and i also have .srt subtitle for them.
now when i try to make video dvd then the nero burner dont support the avi format and adding subtitle is far far away !!!!!!
wel i tried the xillisoft dvd creator too but couldnt add subtitle to the dvd .
so guyz please help me out in this situation ......
thanx
Closed Thread
Results 1 to 9 of 9
Thread: making DVD
Try FAVC or DVD Flick (both free) or ConvertXtoDVD (trialware)
your first post and your cross/double posting
Originally a member since 2001, LONG LIVE TARAN's!!!
Well, he is narcissus, after all...
thnx tomlee!
wel guyz thnx for ur reply
but still i couldnt find any good solution for the problem.
so i'm telling the problem in this way .....
i wanna make a video dvd (from 4700 MB dvd) wch will have four movies in it and also the subtitle , the videos are .avi format and subtitle .srt format.
so please refer some good software that can do it
thnx
FAVC. Choose the VCD setting if you are putting 4 movies on a disc. The resolution will be low, the quality mediocre, but they will fit. If you want something with any level of quality, stick to one movie per disc.
Follow guns1inger's suggestion if you insist on putting four movies on one disc (I'm assuming that each of these movies is itself feature-length). I'm sure you're well familiar with the VCD format, so you can judge for yourself whether that quality level is acceptable to you. If so, then guns1inger's recommendation is by far the best.
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 07:47 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 19:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making a DVD
By Lord Balthazar in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 08:10 -
making dvd;s
By brenjim in forum CapturingReplies: 2Last Post: 14th Jul 2007, 11:48
