So I'm having a problem with my GGW-H20L burner.
No issues when burning cd's and dvd's but every time I try to burn to the included BD-RE disc, the device buffer crashes...to around 15-20%. It's telling me a complete 25gb disc will take about 50 hours. Any idea why that would be?
I have some BD-R's but I'm worried about wasting a $5 blank on something that might be a hardware problem.
Results 1 to 18 of 18
Have you tried different software? Like Imgburn. Try on the bd-re discs.
I did. Same problem. Burned incredibly slowly.Originally Posted by Baldrick
But again, this is only on Blu-Ray discs.
I've even tried burning less information but as a BD-ROM and the same thing happened.
Check for a firmwire update.
it's the most recent.Originally Posted by yoda313
Are you authoring a bluray format video disc? Is it in spec? If you are burning just data it shouldn't take that long I imagine. Of course I only have a bluray rom not a burner so I dont' have personal experience.
I would make sure you are authoring correctly if you are burning a bluray video format disc. There is a chance the program you are using is reencoding the video if it is not compliant.
If this is slow data burning not video I am not sure what the problem might be.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Yep. I tried to just burn some data because I figured there may be a different problem. No difference. It still burned dead-ass slow. I know that RE's only burn at 2x but it still shouldn't take as long as it was going to. At one point, I left it on to see how long it would take to complete and it told me 50 HOURS for one BD.Originally Posted by yoda313
The best part? I call the 24/7/365 LG # and what does it tell me? They're closed until tommorrow.
Sheesh.
Well, this thread may have to be moved to a software forum.
It turns out the problem isn't with the burner: it's the RE disc.
I tried to burn the same files onto a write-once BD-R and no problems. Burned at 6x and played perfectly on my pS3.
So now what could be the problem with the RE disc? I've tried erasing it with 3 different programs, figuring that might be the problem. Still nothing. THe best that I got was it taking about 3-4 hours to burn one film. I think that's burning at about .75, possibly. Still nowhere near 2x.
Wrong brand, not supported or just a BAD DISC.
*** Now that you have read me, do some other things. ***
Wrong brand? It's an LG disc with an LG burner.Originally Posted by [_chef_
Do they have a warranty on these things?
It wouldn't be the first time some blank-DVD-manufacturing company created a bad blank disk with some other company's logo on it.Originally Posted by digitalfreaknyc
I guess my question is whether any programs have problems erasing these bd-re discs, since it is new technology and everything. Is there any evidence of it being a problem?
Are these discs guaranteed?
...of what?Originally Posted by digitalfreaknyc
I'd mail LG about this and ask about resolving the issue.*** Now that you have read me, do some other things. ***
What exactly does that mean?Originally Posted by digitalfreaknyc
First, its BD-RE and you need to format it first properly.
Then, burning time is doubled because of the automatic verifying....*** Now that you have read me, do some other things. ***
Instead of burning a blu-ray movie, I just tried burning some random files on the disc to see if it would take less time and it didn't.Originally Posted by [_chef_
By formatting it, you do it the same way by erasing via Nero or something, correct?
Doubled only on RE?
VERIFY is always on.
Full format with Imgburn.*** Now that you have read me, do some other things. ***
This is the drive that I had to return to LG for repair 3 times. 3 TIMES!!!
It never completed a burning process. I finally sold it on ebay and bought a Pioneer and installed it in my Mac Pro.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
New to Blu Ray burning
By bryankendall in forum Blu-ray RippingReplies: 11Last Post: 28th Aug 2010, 17:31 -
Blu-ray burning problems
By DGenerateKane in forum DVD & Blu-ray WritersReplies: 5Last Post: 13th May 2010, 18:22 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 12Last Post: 15th Oct 2008, 19:51 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
