Frequently I clean up spyware and viruses on customers computers at my home where I have a LAN connected to a satellite broadband connection (Hughes). Usually I'll plug in a Network cable from my Switch Box to their computer so I can download an anti-virus program or maybe pick up some updates and this all works fine even though they have a different high speed ISP than I do. Their HighSpeed Connection may be CableOne or ClearWire or MSN or something similar and when I connect their computer to my network it reconfigures and works great. The problem is ..... When they take their computer back home, they are UNABLE to connect BACK to the Internet. Their network connection does not re-configure automatically back to their ISP and I don't know how to instruct them other than tell them to contact their ISP. I'm probably overlooking something simple and if someone can help me I would certainly appreciate it!![]()
Thread: Network won't re-configure
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
with winXP right click - my network places/properties - right click on the local area connection/repair. older ms os used start run cmd ipconfig /renew. vista right click - network and in the left panel diagnose and repair.
Thanks Aedipuss,
I'll put that in my "Diagnostics" folder for future use!
I appreciate your response."No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
How to configure ffdshow with MPCHC
By skorpinok in forum Software PlayingReplies: 13Last Post: 30th May 2011, 11:18 -
[FFmpeg] configure with libavfilter
By Klagar in forum ProgrammingReplies: 32Last Post: 23rd Nov 2010, 07:37 -
Can't get VobSub Configure to work
By Hunding in forum SubtitleReplies: 0Last Post: 1st Jan 2010, 20:07 -
How to configure windv?
By BonnieW88 in forum CapturingReplies: 3Last Post: 13th Sep 2009, 08:30 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52
Statistics
Newest guides
Latest tool updates
New media comments
