VideoHelp.com Forum
    Hello,
    I am trying to edit a x264/AVC encoded video in a matroska file. I tried to use both VirtualDubMod and VirtualDub (latest versions) to open the .mkv but it failed to open, throwing me an error "Couldn't locate decompressor for format 'ÿÿÿÿ' (unknown)". I also have the latest versions of ffdshow and x264 installed (and they are present in VDubMod's codec list).
    Upon browsing through similar topics, it is said that VDubMod's mkv support is broken and it is impossible to use it to open x264/AVC videos. So I used mkvextract to demux the MKV file and then AVC2AVI to mux the h264 to AVI and finally open it with VirtualDub - and it worked.
    But I still have a problem: I am trying to cut certain parts of the video and use direct stream copying instead of re-processing it (which would take much longer and decrease quality) and while I am able to do that when the segment includes the beginning of the video, I can't extract pieces in the middle of the file.
    So, my question is, what should I use to extract certain portions of a x264/avc video using direct stream copying?
    Thanks for reading
    Try instead avidemux.
  1. Replies: 10
    Last Post: 13th Apr 2012, 04:11
  2. Editing H264 MPEG 4 AVC .ts files?
    By grave101 in forum Mac
    Last Post: 24th Nov 2010, 04:12
  3. Cut HD files (h264/avc) without reencoding
    By cd090580 in forum Editing
    Last Post: 25th Jun 2010, 18:37
  4. VideoReDo now does H264/AVC editing
    By VegasBud in forum Editing
    Last Post: 18th Jan 2010, 04:15
  5. How can i playback avc (h264,.x264) video?
    By therock003 in forum Linux
    Last Post: 29th May 2008, 15:56
