I am trying to put a quad system together, either the AMD 9550 or 9950,. The two motherboard choices are:
Asus M3A32-MVP Deluxe
MSI K9A2 Platinum (ms-7376)
I prefer an Asus board, but the price is higher then MSI board.
Can someone recommend one of these two boards or a more reasonably priced stable board. And what's the minimum power supply I should purchase ?
did u check the reviews on both (newegg.com)>?
do u need the WiFi?
I owned few MSI MB with no issues .they make good videocards ,Laptops,and MB.
I will never pay $219 for any MB -
Thanks for reply. Yes, I've read the reviews. Just wondering what type of boards people are using for the Phenom processors. I talked to an AMD rep this morning that was very helpful, but unfamiliar with motherboards.
My main criteria when choosing a MB is to simply make a list of the options that I want and/or need on the board. That will typically reduce your number of choices. From there, it's a matter of price and/or brand preference while taking into account user reviews.
Google is your Friend
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
HP Laptop help (Is Intel motherboard worth $200 more than AMD?)
By jyeh74 in forum ComputerReplies: 9Last Post: 13th Dec 2009, 15:48 -
Suggestion on motherboard for Intel Core 2 Q9650 Quad Processor
By G)-(OST in forum ComputerReplies: 11Last Post: 28th Jan 2009, 03:13 -
amd slot a processor
By black cloud in forum ComputerReplies: 13Last Post: 13th Sep 2007, 08:08 -
Computer won't boot - motherboard, processor or PSU?
By träskmannen in forum ComputerReplies: 13Last Post: 26th May 2007, 12:26
