VideoHelp.com Forum
    I tried to play a Blu Ray ISO mounted in DaemonTools 4 in PowerDVD 8 but I keep getting a message saying that there is a disk of unsupported format in the (virtual) drive. How can I get the ISO to play?
    I am creating the ISO from a BluRay disk rip on my hard drive and I'm using ImageBurn to create ISO using UDF format version 2.50
  2. BuskerAlley.com zoobie's Avatar
    see if VLC will play it
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    It doesn't seem to work in VLC either.
  4. Banned
    Try installing a UDF 2.5 driver
    (if you still don't have it, of course).
  5. Member Ethlred's Avatar
    Where is the key? If you don't get the key in the ISO then you won't be able to play it without removing the encryption. I assume though that you have removed it since you say you made the image from your HD.
    Also Power DVD is alleged to be quite stubborn about playing anything but a BD-DVD in Blue Ray file formats and I doubt that Imageburn has the knack of meeting the exact BD standard. Most likely it made an oversized DVD image from the files. Then again I don't have BD anything so I am guessing.
    I'm having the same issue. Have ISO image from AnyDVD HD and mounted image with Daemon. Trying to play with PowerDVD Ultra 8. Won't play. Running Vista 32 bit. Any ideas? Thanks!
  1. Problems playing Blu-ray with PowerDVD 8
    By electrontau in forum Software Playing
    Last Post: 27th Jan 2011, 20:29
  2. bluray iso back to bluray format
    By mysts in forum Blu-ray Ripping
    Last Post: 4th Jan 2011, 14:42
  3. PowerDVD DX - Problem playing BluRay
    By cdrake261 in forum Software Playing
    Last Post: 24th Apr 2010, 15:46
  4. Taking Screenshots in PowerDVD while playing Bluray
    By sohaibrazzaq in forum Software Playing
    Last Post: 29th Oct 2009, 13:25
  5. Is iso bluray playing a viable option yet?
    By yoda313 in forum Software Playing
    Last Post: 21st Jan 2008, 13:38
