Seems as though when you hook your ipod to your pc and the songs that were on the ipod isnt on the pc , gets deleted from the ipod..is there a way to get the songs back ..?..are they still on the ipod or lost forever?
If you are using itunes and you have set it to sync to your ipod and you put songs on your ipod on pc 1 then took it to pc 2 and pc 2 deleted them they are gone. Sure you could try some undelete programs but their success will vairy. My recomendation is to check out other ipod managing software like floola, its great and its free.
Don't let iTunes manage everything for you. If you just set your iPod up as an external HDD, and don't let iTunes automatically sync, you don't have this problem. Or only ever sync with one PC.
All in all it is a typical Apple approach - The Apple way is the only way - why would anyone want to do it differently ?
Manually manage it, and you keep control
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
Photostory 3 and Ipod Music
By Megan26 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2010, 07:56 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
How to put music on an Ipod
By tuchodi in forum AudioReplies: 2Last Post: 24th Sep 2008, 13:08
Statistics
Newest guides
Latest tool updates
New media comments
