Hi,
I need to convert a few DV's recorded in PAL format. The problem is that I now only have a NTSC DV camcorder for "playback". So, I am not sure how to feed the DV signal to computer using NTSC "player", while the tapes are PAL? Can I just play the PAL tapes in NTSC camcorder, capture the DV feed in computer through firewire, and then run the conversion on the AVI files created by the capture program? Or, does the conversion would have to be done by the capture software at the time of recording to harddrive? Or, am I out of luck, and have to have a PAL camcorder/player to feed the capture signal to computer?
If it is possible, I will also appreciate a recommendation of software package? Can Adobe Premiere do it?
thanks much.
Have you tried playing these in your camcorder? Almost all consumer NTSC DV camcorders fail to play PAL DV. Some upper range pro camcorders and decks will play PAL DV to the LCD and some transfer. Your options are a dub house or borrow/rent a PAL DV camcorder/player. I see PAL camcorders on Craigslist often.Originally Posted by inspiron2Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
In addition to edDV's advice, sometimes they may appear not to play (e.g., on the LCD or external TV) but the signal still gets sent via FireWire (not very common, though).
If that was the case, you would see PAL video in the WinDV preview monitor while playing the tape to Firewire.Originally Posted by JohnnyMalariaRecommends: Kiva.org - Loans that change lives.
Yes. It is important to have the PAL tape cued (playing or paused) so that the capture software is told by Windows that the DV signal is PAL. If the tape isn't playing/paused, Windows will state it is NTSC.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum CapturingReplies: 32Last Post: 20th Jan 2011, 21:16 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum CapturingReplies: 2Last Post: 17th Jan 2009, 14:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19 -
Pal and NTSC Camcorder
By NightFire in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 20th May 2007, 20:01
