I have an MKV that has video that has a frame rate of 25.689. This has been confirmed via GSpot, Mplayer and MediaInfo.
When I load the following scirpt into HCenc, I get the error in the thread title:
<SCRIPT>
FFMpegSource("C:\mymovie.mkv", atrack=-2)
LanczosResize(720,480,0,0,640,352)
ChangeFPS(25.689)
</SCRIPT>
I also took out the ChangeFPS filter and the same error is generated.
Is HCenc limited to 23.976, 25.00 and 29.97?
Results 1 to 25 of 25
<MEDIAINFO>
General #0
Complete name : C:\mymovie.mkv
Format : Matroska
File size : 233 MiB
PlayTime : 24mn 12s
Bit rate : 1347 Kbps
Encoded date : UTC 2004-08-13 06:55:24
Writing application : mkvmerge v0.9.2 built on Jun 29 2004 23:48:14
Writing library : libebml v0.7.0 + libmatroska v0.7.0
Video #0
Codec : DivX 5
Codec/Family : MPEG-4V
Codec settings, BVOP : Yes
Codec settings, QPel : No
Codec settings, GMC : 0
Codec settings, Matrix : Default
PlayTime : 23mn 54s
Bit rate : 1026 Kbps
Width : 640 pixels
Height : 352 pixels
Display Aspect ratio : 16/9
Frame rate : 25.689 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Title :mymovie
Writing library : DivX503b1263p
Language : English
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 24mn 12s
Bit rate mode : CBR
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Language : English
Audio #1
PlayTime : 24mn 12s
Bit rate mode : CBR
Bit rate : 128 Kbps
Language : Japanese
Text #0
Codec : SSA
Codec/Info : Sub Station Alpha
Language : English
Chapters #0
Language : English
1 : 00:00:00.000 Preview
2 : 00:03:25.100 Intro
3 : 00:04:55.000 Act 1
4 : 00:11:28.510 Act 2
5 : 00:22:10.400 Credits
6 : 00:23:41.000 Preview
</MEDIAINFO>
Originally Posted by Maikeru-sama
mpeg2 is
23.976, 24, 25, 29.97, 30, 50, 59.94, 60
tripp"I'll give you five dollars if you let me throw a rock at you"
I'd recommend this:
I don't like VFR, btw --- many times, the feature is used without a very-good reason.Code:DirectShowSource("movie.mkv", fps=25.000, convertfps=true)
Yeah, I would rather use DSS, but I have been having problems with certain MKV files with DirectShowSource, so I haven't been using it lately.Originally Posted by Midzuki
Anyhoo, If I convert the fps, won't the audio be out-of-sync?
I think I am just going to roll with Quenc, as I have already tried it and know it works (I just wanted to use HCenc for a guide I am writing).
Does ConvertXToDVD re-encode the video?
For this frame rate, I am going to go:
Quenc - no pulldown
DGpulldown
FFMpeg to get the audio
Subtitle Workshop to convert the ssa to srt.
I have already tested one file in TMPGenc, but I want to use ConvertXToDVD, but if it re-encodes, the audio files will be out of sync.
I seem to recall manono saying once that you would just encode at 25fps but since it is really 25.689fps it would still be 25.689fps when done. Just drop the line in the script: ChangeFPS(25.689)
Then afterwards run it through DGPulldown and use the custom option. Enter 25.689fps for the source and 29.970fps for the destination.
Maybe he will chime in but I think that is what he said ...
- John "FulciLives" Coleman
P.S.
I think you have to use HCenc to do this properly ... or CCE ... I don't think TMPGEnc will work."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
MPEG only supports certain frame rates. Those you mentioned and a few others (24 ad 30 I think).Originally Posted by Maikeru-sama
It's been a long time since I have done this but if I remember correctly instead of using convertfps or changefps function I used assumefps(25.00) and then did a custom pulldown 25.689->29.97 with dgpulldown on that output. The result should be a m2v and audio file that should be in sync.Originally Posted by FulciLives
Yep... I even found the thread that I learned that trick from CLICK HEREDonadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Possibly 'DirectShowSource(convertfps=true)' will make the audio track be resampled,
'AssumeFPS(sync_audio=true)' surely will do it. Better add 'ResampleAudio(48000)'
to the script and use another application to recompress the audio
(VirtualDub ++ AC3 ACM, for example).
P.S.: I presume the "trick" indicated by Alex_ander would
only work if the value "25.689" were the actual constant framerate.
Maybe I'm wrong, but it seems Mplayer and MediaInfo are reporting just the
average framerate of a VFR video stream.
P.P.S.: DSS also accepts .gfx (Graphedit files) as input.
Have you already tried them
not if you use directshowsource as midzuki showed. if it's vfr that's by far the simplest route.Originally Posted by Maikeru-sama
and if it's not vfr,
not if you maintain duration.
or in changing speed concurrently change audio speed.
what do you think quenc is doing?Originally Posted by Maikeru-sama
it's changing fps.
yeah that's it.Originally Posted by freebird73717
and it actually came from a thread a week earlier. from me.
anything that maintains framecount.Originally Posted by FulciLives
saying hc can and tmpg can;t is wrong.
as hc doesn;t do processing, it relies on avisynth.
so if you feed the avisynth process to any encoder they'll all work.
i guess what you mean is tmpg's actual internal framerate change filter
doesn;t maintain fframecount.
(anything coming out of avisynth is cfr)Originally Posted by Midzuki
yes it has to be constant,
yes the easiest way to do vfr->cfr (synced) is to use dss.
that sort of dropped out of nowhere...
to author?
yeah i think convertx encodes all.
avstodvd, and the latest betas of dvdflick can take ready encoded parts and do
their simple authoring.
if it's vfr, and you don;t use what midzuki proposed,Originally Posted by Maikeru-sama
almost everything you do will not sync.
That's a cool trick.Originally Posted by freebird73717
Thanks for the comments.
I have a question, I just want to know why the following method is wrong? There are 26 of these files and I just put some on DVD using these steps and everything worked:
1) Used Quenc
2) Used Script below:
<script>
LanczosResize(720,480)
</script>
3) Used MKVExtract to get the SSA file from MKV
4) Used Subtitle Workshop to convert SSA to SRT
5) Used FFMpeg to get the English and Japanese audio
6) Used DGPulldown and went 25.689->29.97
7) Used ConvertXToDVD to render the DVD Files
Of course I didn't do any of this by hand (except for ConvertXToDVD) as the tool TShed did it all for me.
I tested the output and everything was insync. Why is this method wrong, is the DSS way Midzuki spoke of just more efficient and how would using DSS with audio sync work when your goal is Dual Audio.
Everyone that has posted on this forum knows more about this stuff than me. I want to write a guide for something and the above was how I was going to do it, that is why I am asking.
if it's working, it's not.Originally Posted by Maikeru-sama
there's just been a stong hint of vfr material, because of the container
and the abnormal framerate.
if it's working it's not vfr,
or you're imagining sync.
that's interesting regarding quenc framerate change.Originally Posted by Maikeru-sama
not what i'd guess if pushed to guess.
still,
i'd not want to rely on it.
rather, i'd doOriginally Posted by Maikeru-sama
and use any encoder.Code:FFMpegSource("C:\mymovie.mkv") LanczosResize(720,480) assumefps(25)
also remove audio loading in ffmpegsource,
costly.
and that would mean one can author in convertx,Originally Posted by Maikeru-sama
leaving sources untouched?
did you try the tools i mentioned?
if nothing else you could see how they automated authoring
the sameOriginally Posted by Maikeru-sama
45Tripp, I have restarted my batch encode and will use your script:
Sitting here looking at Quenc fire up, you are right that it seems to be alot quicker less the atrack. I thought it was standard to explicitly disable the audio, that is why I was doing it.Code:FFMpegSource("C:\mymovie.mkv") LanczosResize(720,480) assumefps(25)
Also, the way I did it the audio/video was in-sync along with the subtitles.
As Freebird, Fulci and myself stated, I will again use DGPulldown.
I am familiar with both DVDFlick and AVSToDVD and along with FAVC, they are my backups in case ConvertXToDVD fail as I think it is a better product.
I am going to do something different with the audio. Instead of using FFMpeg, which works, I am going to extract the audio with MKVExtract. In the past, whenever I have used MKVExtract, there was always an a/v synch issue, that is why I started using Mencoder or FFMpeg to get the audio.
DirectShowSource has been acting up on both my PCs, when I use it with Quenc and HCenc (CCE is fine). Even when I disable the audio, I still get the basic windows error and they crash.
Well there is always DGAVCDec which is what I use when I have an MKV with H.264 video. First you demux so you get a video only file which will be called something like filename.h264 then load that into DGAVCDec which makes a project file. You then load that into an AviSynth script. Same principal as when you use DGMPGDec with an MPEG-2 source like a DVD rip.
So your MKVs are CFR and evrything is going through the easy path?
Good! You're lucky!
Still, I'd like to know how/where/why the value 25.689 fps was found...
even though Mr. 'Unknown Releaser' will never come give us an answer
to this question.
Do you plan/intend to get into "The Scene"I want to write a guide for something and the above was how I was going to do it,
Not sure. When dealing with Anime, I have seen a ton of weird frame rates and most of them were CFR. I'm just glad this thread didn't go 4 pages, as is usually the case when I postOriginally Posted by Midzuki
I have 2 questions for everyone so I can get a better understanding of why everything works:
1) Why did you choose "AssumeFPS(25)"? Is it because the FPS of 25.689 is close to 25? I had an AVI file a while back that was 20 FPS, would you still have used 25?
2) As mentioned prior, I put AssumeFPS(25) in the avisynth script. How is it that the audio and video are insync, when the video was encoded at 25 fps and the audio is still 25.689? Is it because I did a custom pulldown with DGPulldown?
YepOriginally Posted by Maikeru-sama
Not sure if it would have made a difference but I would have probably used 23.976 and then did a custom pulldown.I had an AVI file a while back that was 20 FPS, would you still have used 25?
Yep. Same just like when you do a pal to ntsc pulldown and the audio is in sync.2) As mentioned prior, I put AssumeFPS(25) in the avisynth script. How is it that the audio and video are in sync, when the video was encoded at 25 fps and the audio is still 25.689? Is it because I did a custom pulldown with DGPulldown?
Ya gotta hand it to the guys at doom9 like donald graft (aka neuron2-author if dgpulldown) and Xesdeeni for even coming up with the idea of irregular pulldown
dgpulldown is just a damn handy tool.Donadagohvi (Cherokee for "Until we meet again")
Thanks for the response Freebird.Originally Posted by freebird73717
Yes, DGPulldown is a great tool. Been using it for a long time, I just never really took the time to understand what was going on.
Not to take anything away from those guys, DGPulldown is a great program. But 3:2:3:2:2 pulldown was around long before they thought of it. I was IVTCing 3:2:3:2:2 caps a few years before then with TMPGEnc Plus's manual pattern method.Originally Posted by freebird73717
you should troubleshoot thatOriginally Posted by Maikeru-sama"I'll give you five dollars if you let me throw a rock at you"
Yeah, it is starting to become annoying.Originally Posted by 45tripp
Here is the error in FitCD. When I get this error, I know I am going to have some problems if I use DSS.
Here is what Quenc does. But after I hit ok a couple of times, it starts to encode:
When I get home, I am going to upload a sample of my m2v output rendered by HCenc, using FFMPegSource. When encoding MKV, using FFMPpegSource, HC and Quenc at times, has some weird output, can't describe it, seems like some of the scenes are pixelated, like there was an error while encoding that frame. I will just upload it, so people can see it.
I haven't made a big deal about it because normally I just turn around and use CCE and it is fine. But I don't want to use CCE with this particular video.
Also, the avs script opens up fine in VDM.
What tool can I use to cut an M2V file? I am trying to load my M2V file into MPEG StreamClip, but it just crashes right when it gets to the end of loading it.
I would like to upload a sample so people can view it.
Here is a screen print of the problem I spoke of when I use FFMpegSource with MKV files:
Alot of frames have this pixelation in it. I know there are other ways, I just wanted to find out if it maybe something unique to my setup.
Also, I re-encoded using the same avisynth script, encoder (HC), but I changed to DSS and the rendered videos does not have this in it.
i'm sure this has been covered at least a few times in your threads:Originally Posted by Maikeru-sama
open in dgindex,
select a section with '[' and ']',
file-> save project and demux video
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 14:30 -
MPEG Streamclip "limit data rate" disabled
By Dignan. in forum Video ConversionReplies: 7Last Post: 23rd Nov 2011, 12:59 -
Where can I get a program that outputs an "I-frame only" MPEG-2 video?
By Videogamer555 in forum Video ConversionReplies: 8Last Post: 1st Sep 2011, 07:23 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 05:01
