VideoHelp.com Forum
    I am newbie and I am trying to convert a home video to DVD. I am trying to use MSU color enhancement filter on source video (DV) and I think I have found a good setting for my home video.
    But what format(compress or uncompress) should I choose to save my changes? I tried to do uncompress AVI and the estimated file size it huge. I am not sure about compress AVI because I think I will lost some video quality. Please forgive my newbie question. I have tried goggle and search videohelp but I cant seem to find it.
    thanks in advance...
    You can use DV, with minimal quality loss.
    You can use a lossless codec such as huffyuv or lagarith. Both will be large, but far smaller than uncompressed. Lagarith usually comes in at around 30 - 35GB/hour for SD footage for me, but it can vary a little either side of this.
    Or finally, you can frameserve to your mpeg-2 encoder and not have an intermediate file other than the temporary sign-post file created during frameserving.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member edDV's Avatar
    I edit DV source to DV project and print the edit back to DV tape* for backup and then encode DVD MPeg2.
    * or back to a DV-AVI file to hard disk.
    http://www.kiva.org/about
    I am now encoding it to Mpeg2 after saving it to DV (using Panasonic DV codec).
    Thanks for the fast replies...
  5. Always Watching guns1inger's Avatar
    In future I would recommend you use the cenodica DV codec with virtualdub instead. The Panasonic DV Codec has known quality issues.
  6. Member edDV's Avatar
    1. Avoid Panasonic DV codec for home camcorder video. It chops your whites. As sggested by guns1inger, use Cedocida codec instead if you must convert from DV format.
    http://forum.videohelp.com/topic353165.html
    2. What editor are you using? Better to edit in DV format without RGB conversion if possible. Source DV->EditDV->Archive-DV->Encode MPeg2 for DVD.
  1. Replies: 80
    Last Post: 2nd Aug 2011, 02:58
  2. Can You Edit .flv Format Video?
    By dieselpowered in forum Editing
    Last Post: 4th Jan 2011, 12:49
  3. Replies: 3
    Last Post: 2nd Sep 2010, 07:38
  4. Why does the video I edit in Cyberlink look darker after I edit it and post
    By Chubby Johnson in forum Newbie / General discussions
    Last Post: 30th Jun 2010, 05:08
  5. Edit, add, extract WAVE and edit file tags with new Machete 3.5
    By MacheteSoft in forum Latest Video News
    Last Post: 23rd Dec 2009, 10:05
