I have a standard Sony rear projrction 60 in tv. Can this be converted to HDTV and if so - how? Thanks
willie
"Standard"?Originally Posted by wslowell
It doesn't have a model number?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
sorry - it is KP-61U45
willie
Hard to find a spec sheet. Do you have a manual with "Specifcations"?
Some KP series were standard definition, some were HD Ready. These are ~2002-2004 vintage CRT projector models. The HD Ready models would support 480p or 1080i input over analog component and would display between 720x480 to 960x540 progressive or at most 960x1080 interlace.
If it was "HD Ready", it would be labeled as such.
Non-HD models should support up to 720x480p DVD. You may be able to drive them at 480p from an "HD" cable box for a better picture. Check first to see if it will take a progressive DVD player over analog component in progressive mode.Recommends: Kiva.org - Loans that change lives.
Connecting PC to Sony rear projection TV
By seminolemuscle in forum Newbie / General discussionsReplies: 10Last Post: 23rd Feb 2010, 23:03 -
rear projection looks like convergence is off but it's not..
By BroomQueen in forum DVB / HDTVReplies: 0Last Post: 9th Dec 2009, 19:45 -
Sony 65 inch Rear Projection HDTV suddenly displays red bands
By daytonadvd in forum DVB / HDTVReplies: 27Last Post: 20th Nov 2009, 18:28 -
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2008, 23:34
Statistics
Newest guides
Latest tool updates
New media comments
