Results 1 to 9 of 9
    For some reason, the audio in a few of my new AVI videos plays fine, but I can't see anything! I'm using version 7.5, and the video has these components:
    H.264 (Perian), 640 x 480 Millions
    MPEG Layer 3, Stereo, 48.000 KHz
    I tried running it through FFMPEGX, but the result was blocks popping up when there was a lot of movement on screen. Is there anything else I can try?
  2. Member MacDSL's Avatar
    Try VLC.
    Just tried that; same result.
    Install the Perian component.
    I have that installed, too. No change.
    What do VLC and QT say about the streams? Do they properly report what they are, and what their characteristics are?
    And do you have more than one video track? See if VLC thinks so. If it does, select the other video track and see if things start to work.
    I'm not sure what you mean by "streams;" I listed what the QuickTime Player's "Movie Inspector" said the video was.
    VLC says there's only one video track.
    Try running a problem video through iSquint with h264 checked.
    Might be salutary.
    Al Bloom
    OK, that seemed to work. I'll write in again if there are problems.
