VideoHelp.com Forum
Results 1 to 13 of 13
    ok I am thinking about buying this
    http://cgi.ebay.com/NEW-6FT-DUAL-TO-...QQcmdZViewItem
    I was wondering if it supports HDTV? Like if i were to download a .mkv HD file would i be able to view it on my HDTV in full HD? Seems easy enough i hope this is true
    thanks!
    Also my computer does not have HDMI im pretty certain of that
  2. Member MaDmiZe's Avatar
    If your TV supports HD, and your computer has a DVI out and your TV has a DVI in, then this would work.
    But if your computer has regular video out and your TV has same for video in (15 pin pc type) then a regular computer video cable would work also. Giving you any range of resolution suported by both the TV and the computer.
    If your computer has DVI out and your TV has DVI in a DVI cable like that will work. Be sure there is a resolution and refresh rate that both your computer and TV support. You will also need to run audio cables since DVI doesn't carry audio.
  4. Member edDV's Avatar
    DVI is a parallel uncompressed path to the TV. The TV knows nothing about a *.mkv HD file. The computer and display card need to deal with decompression.
    http://www.kiva.org/about
    One more question. if I were to buy a dvi splitter would i be able to use the computer and the TV simultaneously?
    A believe a DVI splitter will work only if both displays support the same resolution and refresh rate. Many graphics cards have two independent outputs that can be configured as one big desktop, two independent desktops, or a cloned desktop (same on both).
    On my HT system I have an HDTV running on one DVI output at 1920x1080 60 Hz and a monitor running on the other DVI output at 1680x1050 60 Hz. They graphics card is in clone mode so the smaller monitor pans over the larger desktop, following the mouse.
  7. Member edDV's Avatar
    It would be much easier for us to answer your question if you ID your display card and TV model numbers. We are just guessing what you have and what you are trying to do.
    Ok when i plug in the dvi to dvi it works but its "jumpy" how do i fix that?
    Here is my tv model and my card.
    Mitsubishi - not sure about model #
    Video Card - NVIDIA GeForce MX 440
  9. Member edDV's Avatar
    Look on the back of the TV to find the model number. The key here is to find what resolutions the Mitsubishi supports. What resolution have you been feeding it?
    NVIDIA GeForce MX 440 is an older card with limited MPeg2 decoding support and very poor deinterlace performance. What is your CPU? What kinds of *mkv files are you trying to play? Are you able to decode these files to the computer monitor?
    ok i fixed the "Jumpy" thing I just switched the res. on the computer to 800x600 which makes the font and stuff terrible but i wanted to use it for just watching HD videos anyway.
    Go back to whatever resolution you were using and enable video overlay. Then use a media player that supports video overlay -- which is most of them. Except Quicktime Player. That should speed up video processing and smooth out the playback.
    I have video overlay enabled?
    Are you saying you do have video overlay enabled? Or are you asking how to enable it?
    Without video overlay the CPU has to convert the video from YV12 to RGB and scale it (if you're running full screen) to the desktop size. If you don't have a fast CPU and fast video bus this is a lot of work for the CPU. The player will end up skipping frames to keep up with the frame rate. The fact that lowering the desktop resolution fixed your jumpy playback indicates this is the problem you were having.
    With video overlay enabled the graphic's card's hardware YUV to RGB converter and scaler are used. Skipping frames is much less likely.
  1. Plug DVI/HDMI adapter to DVI video card?
    By Stealth3si in forum Media Center PC / MediaCenters
    Last Post: 23rd Dec 2010, 19:32
  2. DVI PC output to HDMI HD TV input?
    By eros in forum DVB / HDTV
    Last Post: 26th Sep 2010, 01:38
  3. RF output to DVI/HDMI Input
    By torrentkid in forum Capturing
    Last Post: 19th Jun 2010, 02:41
  4. DVI-I to RGB Input Help...
    By DJDoubleXl in forum Capturing
    Last Post: 16th Oct 2009, 12:07
  5. DVI-D cable in DVI-I slot-possible? Quality loss?
    By bigshotceo in forum DVB / HDTV
    Last Post: 21st Dec 2007, 06:49
