VideoHelp.com Forum
    Hi-
    I'm new to this kind of stuff and not very computer literate.
    The DVD/CD burner in my Gateway computer is a TS-H552D.
    Does anyone know if this is a dual layer burner???
    I would like to be able to make back-up copies of some DVD-9 discs I have, but was told that in order to burn a DVD-9 disc, I need a dual layer burner.
    Thanks in advance for any help!
    Jeff
  2. DVD Ninja budz's Avatar
    http://www.videohelp.com/dvdwriters/...-ts-h552d/1465
    search is your friend......we do have a dvd rewriter section....make sure you're using VERBATIM DUAL LAYER MEDIA....anything but that brand will give you problems such the disc not reading back or playing back correctly...
    Thanks, budz.
    I did see the DVD rewriter section...and I did see my burner listed.
    However, I couldn't tell (and still can't) if it is a dual layer burner or not. I didn't see that piece of information listed. (Unless it's there....and I just don't get it.)
    Thanks for the tip on Verbatim Dual Layer media, too.
  4. Note the two DVD listings with "DL" after them.
    Thanks!
  6. Member LJB's Avatar
    Per Nero infotool:
    DVD +R DL
    DVD -/+ R(W)
    For DVD -/+R my drive works well with Fuji and TDK, but it works best with verbatim media.
    For DVD-RW and DVD+R DL I only use verbatim.
    Please note that I have learned from this forum to burn only with imgburn.
  1. Replies: 7
    Last Post: 18th Nov 2011, 03:16
  2. Dual Layer DVD Burner Use
    By Aristocles in forum Newbie / General discussions
    Last Post: 15th Oct 2009, 01:11
  3. DVD Burner for writing Dual Layer
    By StealthKing in forum DVD & Blu-ray Writers
    Last Post: 1st Feb 2008, 21:25
  4. dual layer DVD-R in single layer burner?
    By snafubaby in forum Media
    Last Post: 4th Oct 2007, 13:39
  5. Replies: 5
    Last Post: 12th Jun 2007, 12:56
