I add some captions to .mov file using Quicktime Pro for Windows and the recommended procedure off of the quicktime user guide. After adding the captions in a new text track and save the move as a self-contained movie everything plays/works on my PC just fine.
Problem is if I try to convert it to .flv format using Riva or another program I found called Any Video Converter (the latter worked, but Riva had a hard time with my h.264 file for some reason), then the text track is apparently stripped away and lost. That is, the captions or text I added don't show up anymore in the flash video. This happens even if I directly upload to youtube or viddler, where I assume they are reencoding to flv anyway on their servers.
Any ideas why my captions are stripped away? If I use quicktime pro to first convert to another format (such as .avi or mp4) the captions stay but I lose some of the quality and the ability to keep it in the 16:9 ratio.
Results 1 to 1 of 1
Problem with MOV > FLV conversion
By sprinke in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2011, 21:11 -
Another MOV to FLV issue
By Nat05 in forum ffmpegX general discussionReplies: 4Last Post: 5th Feb 2011, 14:55 -
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 00:20 -
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 12:15 -
.mov to .flv - Sync issue and shortened video.
By dillingham in forum ffmpegX bugs and suggestionsReplies: 1Last Post: 4th Jun 2008, 16:15
