VideoHelp.com Forum
    Hi all
    i would like some advice/opinions on which custom firmware, that gives best results and features i found a site dedicated to this DVD player (see link) but need some advice
    http://www.phunkyfish.com/article/4/philips-dvp-596012
    many thanks
  2. Member Krispy Kritter's Avatar
    First, any "hacked" firmware will void your warranty.
    Second, there likely isn't a "best" firmware. It will simply boil down to which "version" contains the fix for whatever issue you are having.
    As noted on numerous occasions, if you aren't having any issues or if you don't know for sure that a different firmware corrects an issue that you are having, do NOT update. Simply updating to have the latest version is not recommended.
    Google is your Friend
    OK thanks for the reply i have picked the fimware that supports longfile names and ISO resume play
    But cases of damage of the laser are known at the inattentive (not carefully checked or not carefully mixed) change firmware !
    How with it at yours "handmade" firmware?
  1. philips dvp5960
    By tonie in forum DVD & Blu-ray Players
    Last Post: 11th Sep 2008, 14:58
  2. Philips DVP5960/12 Firmware 12.06.36.24 download it here
    By F-Swed in forum DVD & Blu-ray Players
    Last Post: 11th Apr 2008, 21:48
  3. Replies: 13
    Last Post: 18th Nov 2007, 14:47
  4. Philips DVP5960 Help
    By clubfoot in forum DVD & Blu-ray Players
    Last Post: 13th Sep 2007, 05:39
  5. Philips DVP5960 dies during firmware upgrade. HELP!!!
    By croft in forum DVD & Blu-ray Players
    Last Post: 15th Jun 2007, 11:21
