Hi,
I want to buy a dvd recorder with Hard Drive.
I didn't wanted to spend more than 200/250€.
Can anyone sugest me a decent one?
It's to convert all my vhs to dvd. None of this vhs are comercial but must of them has high generation copys. So has to be a dvd recorder that wont give me sync problems between audio and video.
Any sugestion?
By the way... i never user any dvd recorder, it's possible to recorder like 180minutes and edit it to burn only what i want?
Thanks for your time
I can highly recommend the Philips DVDR3575H/37 if you're in North America.
Click my signature for lots of organized info where you can read what you want to know now andlater when you go to set up and use.
Toshiba, if you can still buy them wherever you are. There are more options for customizing than you'll ever need and PQ is the best there is. Noise reduction on the input and output side both, black level adjustments for input and output both, those may come in handy for VHS.
Your price is a little Low I would advise spending £200 or 300Euros and getting a nice sony or phillips or Panasonic. Most of the other lesser brands tend to be a bit .. well.. "wonky".. possibly will work, not as reliable,not as user friendly, not as well made, not as well supported.. or you may pick up a gem, as they have to prove themselves
The electronic components of the power part adopted a lot of Rubycons.
one year later and i still didn't bought the dvd recorder.
can anyone recomend me again on a good recorder? around 250€/300€ top
Theres any combos that convert pal and ntsc to dvd? i'm in portugal so here we have PAL but i have a few NTSC tapes too..
THanks
Check the Panasonics, the UK ones can be switched between pal and ntsc in the menu.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Transferring AVI to Sony Hard Drive recorder - Advice please
By porty in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 03:33 -
Looking for a DVD recorder with hard drive
By sldvd in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jun 2009, 09:30 -
dvd recorder with hard drive?
By chuckliddell101101 in forum DVD & Blu-ray RecordersReplies: 31Last Post: 24th Jan 2009, 17:51 -
DVD Recorder vs. Hard Drive
By docref in forum DVD & Blu-ray RecordersReplies: 9Last Post: 14th Aug 2007, 00:27 -
Buy DVD Recorder w/ or w/out a hard-drive?
By csmith in forum DVD & Blu-ray RecordersReplies: 8Last Post: 15th May 2007, 02:55
