VideoHelp.com Forum
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    So I went to use DVD Shrink 3.2 to edit a dvd like I have for the past 4+ years, and when I went to back it up, it was only encoding @ about 2500KB/s (and taking 20+minutes), instead encoding @ 24000+KB/s (and taking 3+ minutes) that it has been since I got this AMD dual core PC. I tested it on several different movies and all were encoding at the slower speeds? Any ideas what just all of a sudden made the encoding process totally slow to a crawl?
    ~ I have tried deleting all the files in the C:\Documents and Settings\All Users\Application Data\DVD Shrink folder.
    ~ I have defraged the drive that I use for backups.
    ~ The files are already ripped to the Hard drive, so it's not DMA/PIO mode problem, ripping is working fine as normal
    ~ The box within the DVD Shrink preferences marked Run analysis and backup in low priority mode to improve multi-tasking is UNCHECKED
    ~ I'm not running deep analysis
    ~ I've uninstalled dvd shrink and all it's files (then ran CCleaner). And re-installed DVD Shrink 3.2 and the problem still exists.
    ~ I've run Spybot, McAfee, CCleaner, Windows Defender and no malware/adware was found.
    I have no idea why just out of the blue it now in codes so slowly
    What We Do In Life, Echoes In Eternity....
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Ok so I went and looked in the Device Manager and found that my 3rd Secondary IDE Channel was stuck on PIO MODE. So I uninstalled the driver and re-installed it and all is good?
    I didn't think it was a PIO problem only because I thought that only had to do with dvd drives and and hard drives (Learn something new everyday.)
    So luckily I've got it back to normal again.
    could be it's transcoding, is the movie over the size limit for a single layer dvdr? shrink is much faster when just copying out the files if it's display bar is under the 4.35GB limit and it runs in that mode at 60,000KBs on my system between 2 separate drives.
    it could still be the drive(s) in the wrong mode even though it's already ripped, or possibly a dying drive which can slow the whole system to a crawl.
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Thanks for the help, but I got my last post in at the exact time as you....LOL.....thanks again for the intended help though.
    wow a posting tie
  6. Disgustipated TooLFooL's Avatar
    you are correct, but since shrink is reading and writing to the HDDs during the encode process, PIO mode will slow things to a crawl. switching to SATA drives speeds up the process even more!
    I am just a worthless liar,
    I am just an imbecil
  7. [url=http]text[/url] Denvers Dawgs's Avatar
    Already using SATA drives.
  1. Will DVD Shrink shrink an ISO image?
    By brassplyer in forum DVD Ripping
    Last Post: 30th Sep 2011, 03:46
  2. anyone know how to unlock denon dvd-2500 regions
    By similar in forum DVD & Blu-ray Players
    Last Post: 10th Jan 2011, 14:03
  3. Replies: 35
    Last Post: 18th Nov 2009, 12:33
  4. Tool for VCD at 2500 bitrate with No Re-encoding
    By whenloverageswild in forum Authoring (VCD/SVCD)
    Last Post: 6th Mar 2009, 11:34
  5. how to shrink a movie with DVD Shrink?
    By php111 in forum Newbie / General discussions
    Last Post: 22nd Aug 2007, 17:59
