VideoHelp.com Forum
Results 1 to 9 of 9
    My capture is only showing in black and white any ideas how to change in to colour
    Not a lot to go on but the commonest problem is trying to use an S-Video input with something that can only output composite. What is your source and what input are you using on the capture device?
    Capture dvice involved first, the specifics can be confirmed as to what the issue is
    I've got the same problem with a Hauppauge HVR 1800 MC Kit. It has an adapter to connect composite to S-Video but the video is in black and white using S-Video in WinTV and nothing appears on the screen if I choose Composite.
    im using a dazzle dvd recorder and im using a scart to triple phono lead and normal 360 cables
  6. Member hech54's Avatar
    MORE INFO NEEDED!!!!!!!!!
    Don't tell me....you are trying to capture a video game of some sort?
  7. Member SHS's Avatar
    What a 360 cables, Are you ref to the Xbox??
    What you using VCR??
    Richard_G you forgot one if the device is PAL 60 only it may come out black and white.
    ye i mean the xbox and im trying to capture a video game and no im not using vcr
  9. Member hech54's Avatar
    I've read that most video games are NTSC....you are PAL. You are trying to capture a quasi or hybrid signal that is neither NTSC or PAL....which capture cards and DVD recorders don't like.
  1. PAL Capture Black & White
    By SGGS in forum Capturing
    Last Post: 9th Dec 2011, 04:12
  2. PAL Hi8 Capture Black & White
    By SGGS in forum Mac
    Last Post: 8th Dec 2011, 09:15
  3. Black & White Capture w/ Dazzle!
    By Rowan88 in forum Capturing
    Last Post: 12th Mar 2010, 13:42
  4. Replies: 2
    Last Post: 3rd Nov 2009, 06:34
  5. video capture in black and white only
    By oldboy29 in forum Capturing
    Last Post: 13th Jan 2008, 17:54
