VideoHelp.com Forum
    Sata Optical: Pioneer DVR-212D
    Motherboard: Abit NF7-S v2 Sata
    Sata Optical DVD drives compatible/work on the NF7-S V2 Motherboard ?
    Anyone had success getting a SATA dvd burner to work directly plugged into the sata1 or sata2 socket on this motherboard and NOT through a PCI card. Sata harddrive and ide drives all working perfectly just testing Sata optical burner on this board.
    I have tried Pioneer DVR-212D in 2 other PCs with onboard SATA ports and it works perfectly no corrupt data or freezing. This motherboard/bios old never designed to run Optical sata drives?
    Pioneer DVR-212D will burn dvds but when I verify them there are errors (Verbatim/TY only media used). How do you enable "Look Ahead" and "Write Cache" options see below this anything to do with the corrupt data and verify errors?
    tia.............
    DEVICE MANAGER INFO:
    Silicon Image Sil 3112 SATARaid Controller Properties:
    Type: CD-ROM
    Model: Pioneer DVD-RW DVR-212D
    Firmware Version: 1.24
    ATA Version: ATA/ATAPI-7
    Look Ahead: Unsupported
    Write Cache: Unsupported
    Current Transfer Mode: Ultra DMA Mode 4
    Serial link speed: Generation 1 (1.5Gb/s)
    -IDE ATA/ATAPI controllers
    Primary IDE Channel
    Secondary IDE Channel
    Standard Dual Channel PCI IDE Controller
    -SCSI and RAID controllers
    Try disabling RAID in BIOS. I've read where SATA optical drives don't work correctly with RAID enabled.
  3. DVD Ninja budz's Avatar
    you have NVIDIA chipset controller therefore you'll need to download the latest drivers from the NVIDIA website. don't download them from the mobo website. also make sure SATA is set to IDE in your mobo bios and as mentioned disable RAID in mobo bios as well.
    if all of the above is done and the 212 doesn't work correctly you may have to buy a PCI SATA CONTROLLER CARD that has the SILICON IMAGE 3112/3114/3512 chipset.
    His SATA RAID controller is Silicon Image Sil 3112 and other controllers may be Silicon Image too for which a PCI adapter may not help. Most likely the budz suggested BIOS changes should resolve the problem.
  5. DVD Ninja budz's Avatar
    I did see he has the 3112 chipset but it's RAID so it's not gonna help him with his problem. That 3112 chipset is on his mobo which usually you can just shut the RAID off in the mobo bios. But if there isn't that option he would still have to buy a SATA PCI CONTROLLER CARD which can be flashed to be NON-RAID where his mobo isn't capable of that.
  6. Member [_chef_]'s Avatar
    Depending on the BIOS, only disabling SATA Controller BIOS just works wonders.......
    *** Now that you have read me, do some other things. ***
  1. Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
    By psymaster in forum Newbie / General discussions
    Last Post: 31st Oct 2009, 19:48
  2. Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
    By psymaster in forum Latest Video News
    Last Post: 31st Oct 2009, 17:26
  3. Replies: 1
    Last Post: 13th May 2008, 07:20
  4. Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
    By Thommo1978 in forum DVD & Blu-ray Writers
    Last Post: 3rd Feb 2008, 06:02
  5. Pioneer DVR 212D won't read Some CD's
    By Regm in forum DVD & Blu-ray Writers
    Last Post: 31st Jan 2008, 16:31
