Can anyone recommend a good analgue video capture card/box that is compatible with the 64-bit version of Vista? I have a Dazzel DVC-130 that was great for 32-bit, but no drivers are available for the 64-bit version which we've now migrated to.
Prefer a USB2 or Firewire box over a PCI card, but do have a PCI slot free if necessary.
Will be used for converting old sVHS (ie S-Video input required for best quality) and archiving to DVD (editing in Premiere CS3 first).
Tennant
Tennant
There Can Be Only One
Sony HVR-Z1E, Interfit lighting, Adobe Premiere CS3 and Apple Final Cut Pro HD edit suites
Depending on your budget, a dedicated analog-DV converter box will work (~$140).
John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
Yes, at least 64bit works with DV import. Some choices
- DV camcorder with "analog pass through". It will need black correction (32 to 16) after capture.
- Canopus ADVC DV transcoders (has 0.0/7.5 IRE switch for proper black capture).
- ADS Pyro DV transcoders (fixed to 7.5 IRE capture).Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I was thinking along similar lines. Was going to go for the Canopus ADVC 300 as I think the TBC will be useful for some of the older tapes.
Any reasons not to go for this?
Tennant--
Tennant
Which codec to play this MPEG video on Vista x64?
By pcgurusaxguy in forum Software PlayingReplies: 4Last Post: 4th Jun 2009, 14:41 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum CapturingReplies: 3Last Post: 18th Jan 2009, 18:29 -
Best codecs for Vista x64
By dbone1 in forum Software PlayingReplies: 0Last Post: 31st Dec 2008, 10:24 -
Capturing analogue under vista Sound twice as fast as video
By djain91 in forum CapturingReplies: 1Last Post: 11th Jul 2008, 17:36 -
Vista x64 ?
By seadragon in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Nov 2007, 04:45
Statistics
Newest guides
Latest tool updates
New media comments
