  1. Member cobra jet's Avatar
    Aug 2006
    California
    Does anyone know where I can get a picture of the DVD logo that has a transparent background? I would like to place it on my current project and can only find ones with a colored background. I know that I could probably fix it in Photoshop but my hand is not that steady for that type of work.
  2. Member LJB's Avatar
    Feb 2007
    For an image file:
    Resize the logo to the disired size.
    Change the black of the logo to any level of grey within the greyscale.
    Place in the location desired on a blank page with the page size equal to the project size, for example 720X480 or 320X240.
    Use as a greyscale mask to place the watermark on the image.
    I use an image editor called Photofiltre to do my watermark masks.
    Just an FYI - You can't use that logo without permission. It's copyrighted. I know that people use it all the time but they are technically violating a copyright by doing so without permission.
    http://www.dvdforum.org/format-format.htm
  4. Originally Posted by SCDVD
    You mean trademarked.
    Darryl
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    You use a font in your photo app.
    http://forum.videohelp.com/topic290447.html#1446642
    http://forum.videohelp.com/topic290447.html#1446066
