hi bros,
i have dvd recorder sony RDR-HX750 but i have a small question .
i have 2 choices , i can record on DVD disc and on HDD but i want to know what if i need to record the film from HDD to the disc how i can do this ?
or there is any other facility to transfer the files which i recorded to the computer ?
thanks for your help .....
Do you have the instruction manual, or can you go to the Sony website and download it? That would be the most helpful thing for you. The RDR-HX750 is similar to several Pioneer models, although I believe Sony uses different on-screen displays. Most likely, you need to go to the "home" or "main" menu and select a "copy" option, in this case "HDD to DVD". The recorder will present you with a list of programs you have stored on the HDD, you select the ones you want to copy and then confirm the burn, it will then make a DVD for you which must be "finalized" using another menu option. It can get a little complicated sometimes, like if the program on your HDD cannot fit a DVD you have to make additional choices to fix that. This is why you should get the instruction manual, it explains these things in detail.
There isn't any direct way to move programs from your Sony recorder to a PC, you will need to make a DVD first which can then be "ripped" to a PC for further authoring.
sony RDR-HX750 problems with divx-subtitles
By eclecticus in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Apr 2009, 14:39 -
Sony RDR-RXD890
By dixons in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Mar 2009, 23:37 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR-HX750 Stopping for copyright
By rtimboz in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Jun 2008, 13:42 -
Sony RDR-HX750
By woutie in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Sep 2007, 09:54
Statistics
Newest guides
Latest tool updates
New media comments
