I am using Virtualdub, and i have the video loaded in. I am using direct stream copy. I click the [HOME] key to mark where i want the video to start, and the [END] key to mark where i want the video to end. It's supposed to save that section of the video, but for some reason it's not doing it. It's starting the video too late. Anyone have any tips to help things along? thanks
In Direct Stream Copy mode, any section you keep must start on a keyframe. If you mark-in on a non-keyframe VirtualDub automatically saves from a nearby keyframe mark-in. Hold down a shift key while seeking and you will only stop on keyframes.
This is because the frames between keyframes only encode the differences between successive frames. Without a keyframe there is no way to reconstruct the entire image.
Use VirtualDub's Smart Rendering feature if you want frame accurate editing and minimal re-encoding (only cut GOPS are re-encoded). -
Originally Posted by jagabo
If you're not doing any filtering use Fast Recompress mode. That will avoid YUV to RGB to YUV conversion. Enable the Smart Rendering feature with Video -> Smart rendering. Set the compression codec to the same codec as is used in the source video. If the source is uses CBR (constant bit rate) encoding set the codec to CBR at the same bitrate. If the source is VBR (varialbe bit rate) set the codec to single pass, constant quality encoding, with a high quality setting. For example, in Xvid set the encoder to Target Quantizer mode and set the Quantizer to 3.
Cut part of High Definition Video
By Bruno AUgusto in forum EditingReplies: 4Last Post: 15th Nov 2011, 08:20 -
How cut a part of an AVI video?
By DCRC in forum ffmpegX general discussionReplies: 4Last Post: 17th Sep 2011, 13:04 -
How to cut a 3gp video file to part files without a reencode?
By kop in forum EditingReplies: 2Last Post: 20th Oct 2008, 13:33 -
By kop in forum Portable VideoReplies: 1Last Post: 20th Oct 2008, 01:16 -
How cut part of .flv video?
By method in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2007, 08:31
