VideoHelp.com Forum
Results 1 to 9 of 9
    Hey all,
    I've got the Sanyo xacti hd1000, loving the camera and have finally worked out a good workflow for editing etc.
    I can encode back out to 720p/1080i fine after editing using staxrip and other encoders, however these files don't playback on the camera when copied back over. I think this is because sanyo use a proprietary h.264 codec or something.
    Just wondering if anyone knows of any encoder that will output a h.264 hd file that will playback on the xacti hd1000 camera. So I can playback the edited video on my tv in hd without burning to blu-ray etc
    Cheers
    Joe
    Could you post all the video details of a camera video file? Use for example MediaInfo.
    It's not an easy job to encode your video so it
    fit's within the camera's playback structure.
    See also:
    http://forum.videohelp.com/topic351586.html
    I am still busy to get the job done trying to
    analyse the way thumbnails are working together
    with the videofiles.
    Panasonic or Sanyo is not of a difference, i think.
    Hey, thanks for the replies. Here's the output from MediaInfo:
    General
    Complete name : F:\My Stuff\Irvine\SANY0441.MP4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 345 MiB
    Duration : 3mn 58s
    Overal bit rate : 12.1 Mbps
    Movie name/More : SANYO DIGITAL CAMERA HD1000
    Encoded date : UTC 2008-06-21 14:58:29
    Tagged date : UTC 2008-06-21 14:58:29
    Origin : Digital Camera
    Video
    Format : AVC
    Format profile : Baseline@L3.2
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Duration : 3mn 58s
    Bit rate mode : Variable
    Bit rate : 12.0 Mbps
    Width : 1280 pixels
    Height : 720 pixels
    Display aspect ratio : 16/9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Original frame rate : 29.970 fps
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.217
    Stream size : 341 MiB
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 3mn 58s
    Bit rate : 128 Kbps
    Maximum bit rate : 192 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 3.62 MiB
    Language : English
    i'm also trying to find out about this problem. I'm trying to get avisynth to recognise files from the xacti hd700. the mediainfo output is exactly the same as the op's.
    dgavcindex gives errors and DirectShowSource() also fails.
    @iubo - you probably have to use the same specs for playback, i.e. AVC, Baseline Profile, level 3.1 or lower - this means no trellis, no CABAC, no b-frames, no I8x8
    @flywitness - I can confirm both DGAVCdec and DirectShowSource() work fine with HD1000 for encoding, or did you mean for playback on the camera? If so, just emulate the settings upon encoding and it should work
    Do you have a recent avisynth install? h264 decoder (e.g. libavcodec turned on in the ffdshow configuration or coreavc pro installed)?
    If you still can't get it to work (clarify if you meant for playback or for encoding), can you post a HD700 clip to a free hosting site, such as mediafire or megaupload
    Don't use DirectShowSource, all it does is desync the video and I wouldn't except a video camera to playback files that it didn't create.
    i want to playback the material with avisynth and pipe it to avidemux via wine and avsproxy.
    i am running ubuntu linux. I've installed ffdshow under wine. i am trying to get mediaplayer classic to play some files but so far no luck. i don't know if it's because my setup is wrong of if its because my computer just can't handle the files.
    the only success i had so far is using mp4camtoavi to convert my material to avi and than i can use AVISource() to open it fine. This is all well and good but i want to know why i can't index it with dgavcindex? ive done it before on m2ts files.
    It might be a WINE and/or Linux issue. You might have better luck asking in the Linux section
    Did you "turn on" h264 in ffdshow configuration (set to "libavcodec")?
    Do you have a .mp4 splitter installed (e.g. haali media splitter, or gabest)?
  1. xacti vpc-hd1000 to avchd without reencoding
    By rsalest in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st Oct 2010, 15:05
  2. Xacti HD1000 camcorder/camera video plays horribly
    By matthewmachugh in forum Newbie / General discussions
    Last Post: 16th Mar 2009, 13:45
  3. Replies: 33
    Last Post: 10th Jun 2008, 14:47
  4. Sanyo Xacti HD-1000 and Toast 9
    By farfel81 in forum Mac
    Last Post: 2nd Jun 2008, 19:12
  5. Sanyo Xacti HD1000
    By miepel in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Jan 2008, 09:02
