Is there dynamic range compression in the VLC player? How is it activated and controlled? Thanks!
Results 1 to 9 of 9
Thread: DRC in VLC?
Yes, I second that wish. I often watch video in a noisy environment, and this is sometime excruciating to have to change the volume all the time...
Settings -> Preferences
Tick Advanced Options in the bottom right corner
Then go to Audio -> Filters -> Volume Normalizer
Thanks for the hint, but I'm looking for DRC and not volume normalization (which is quite different, and doesn't suit my needs).
Too bad, got a mac. =\
I also found out, that what I am looking for may be "automatic gain control" actually... Still looing into it.
What, specifically, are you trying to fix ?
I want to make loud parts of the movie quieter and quiet parts louder.
This is want dynamic range compression in audio means, as far as I understand.
AGC is realtime and evil IMO. Too much pumping.
I think what you want is "audio compression" which in the audio context means dynamic range compression, not bit rate compression. All AM raadio stations rely on dynamic range compression.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 29Last Post: 23rd May 2012, 05:06 -
What Kind of Partition and OS for RCA DRC 8030N
By kasitrol in forum DVD & Blu-ray RecordersReplies: 7Last Post: 4th Apr 2011, 08:19 -
AC3 - figure out dynamic range compression (DRC)
By Lariel in forum AudioReplies: 2Last Post: 12th Feb 2011, 09:33 -
How to stream using VLC
By dafodill in forum Software PlayingReplies: 4Last Post: 29th Jun 2010, 17:23 -
VLC Problem
By Basketbits in forum Newbie / General discussionsReplies: 3Last Post: 12th Jul 2007, 12:27
