I am new to ffmpegX, and think it's a great idea. However, I probably don't understand how to setup and use it properly (yet).
I am trying to convert some *.wmv files that I have made from some old 8mm video cam tapes years ago. I want the output to be something that I can use with iMovie, Hyper-Engine AV, and others. Either they won't take .wmv files or they import thru Flip4Mac and it has a watermark since I don't want to buy it.
When I try to convert, 1 of 2 things happens with ffmpegX:
1. It is done instantly and the file is empty (it says finished or failed, depending on the format I am trying to use)
or
2. It says completed, but only the first 10-15 minutes of the original file is there. Seems the only format I can use for output is an iPod setting- none of the other presets... .mov, .dv, .mp4, etc produce anything.
Any ideas why I can't convert a whole file? Some are up to 2 hours long.
I have read numerous postings here and will, and have made certain everything is in the correct place and followed instructions you've left for other newbies. I guess I'll finally figure out how to make it work- or just go out and buy a commercial solution or do the conversions on a PC (I really dislike being held hostage by Flip4Mac when I convert .wmv).
Thanks in advance for help from you experts.
Greg
Results 1 to 1 of 1
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 05:26 -
SUPER won't endcode full file, why not?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 11th Jun 2011, 18:22 -
File Formats
By Dan K in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2008, 11:22 -
help with eac3toGUI, won't re-encode file
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 17:32 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
