VideoHelp.com Forum
Results 1 to 11 of 11
    I am having trouble removing the back part of the enclosure that has the switch off. It has all these wires attached to it that are just hanging . I know, i'm a newb when it comes to these things. I'm trying to install it as an internal drive.
  2. DVD Ninja budz's Avatar
    If you're trying to convert a external dvd burner to a internal one that may not be possible. Easier to just order a internal dvd burner since their so inexpensive.
  3. Member Noahtuck's Avatar
    Yep...
    What budz said....
    You can buy a new top of the line quality internal dvd burner SHIPPED to your door for around $35.00 avg.!!!!!!!!
    Some even as cheap as $30.00!!!!!
    www.newegg.com
    Originally a member since 2001, LONG LIVE TARAN's!!!
    Thanks guys, I just ordered a Pioneer DVR-115DBK DVD/CD Writer online. Does ram size really matter for internal burner? Because the computer i am currently using has 224mb of ram.
  5. DVD Ninja budz's Avatar
    That's not a lot of ram....you should have posted that question before you purchased the 115D...my suggestion is to contact Pioneer and ask them about it. Although I don't think it should affect much of the burn process but it could prevent you from burning faster than 8x speed. Make sure you use a 80 wire ide cable with your new 115D drive.
    Pioneer Support Phone Number: 1-800-421-1404
    I uprgraded it, by taking some from my old pc (I was a little hesitant at first) but got it to work. Now, ii has 704mb of ram. Do you think that will be enough?
  7. DVD Ninja budz's Avatar
    that should be fine with 704mb. what type of ram are you using? post your computer specs. when you get the drive try burning a disc at 12x speed. that's the only way you'll know for sure if it will burn at faster speed with the amount of ram you have.
    Windows xp pro sp2
    Compaq Presario SR1610NX Desktop
    Dual Channel Support: Yes
    CPU Manufacturer: AuthenticAMD
    CPU Family: AMD Sempron(tm) Processor 3200+ Model 15, Stepping 2
    CPU Speed: 1790 MHz
    currently installed-256mb DDR PC3200
    512mb
  9. DVD Ninja budz's Avatar
    your computer specs. should be fine with your new Pioneer 115D drive.
    Thanks for all your help. Since i installed the 512mb it seems like my external burner has no errors at 4x., which is a little slow so I will buy some more ram soon so when I get my pioneer I can hopefully run both burners at the same time or burn at higher speeds. Thanks again
  11. DVD Ninja budz's Avatar
    your welx!
  1. Combo enclosure for blu-ray burner and HD
    By sharjohn in forum DVD & Blu-ray Writers
    Last Post: 20th Nov 2010, 04:09
  2. taking a bit out of a home dvd
    By galaga-girl in forum Editing
    Last Post: 5th Sep 2010, 06:25
  3. DVD-RB with CCE taking 18 hours...
    By hiimbored in forum DVD Ripping
    Last Post: 23rd Nov 2008, 16:03
  4. Taking screenshots from DVD?
    By PatBateman in forum Editing
    Last Post: 15th Nov 2007, 14:44
  5. Taking Audio off of a DVD
    By IrishToken in forum Newbie / General discussions
    Last Post: 3rd Jul 2007, 20:08
