Dear Chrissboy - I must first, extend my best wishes, to your wonderful software. I absolutely think it is the fastest and easiest conversion software I have found thus far.
I am experiencing a problem with trying to convert a DVD on the harddisk to usable .mpg files. It says :Finished processing 0 vobsets. Duration 00:00:00 . I can not find the c:\Program Files (x86)\BaderIT\Log folder? Ideas, Vista64Ultimate running v2.5 and trying to encode SM ALL VILLE_SEASON_1_DISC_1 ? (I even tried to create a \Log and \Logs and nothing was written to it)
Your software has worked for me on the other DVD's, so I seem to have a stubborn one. If I open a .vob in WMP, it will eventually allow me to find the root menu, so i think that my rip has been successful.
I would appreciate your thoughts -
the directory sturcture... ( there are no spaces in directory name between M and A and L and V -just want to fool the web crawlers)
C:\SM ALL VILLE_SEASON_1_DISC_1\VIDEO_TS>dir
Volume in drive C has no label.
Volume Serial Number is A800-BD64
Directory of C:\SM ALL VILLE_SEASON_1_DISC_1\VIDEO_TS
06/20/2008 03:08 PM <DIR> .
06/20/2008 03:08 PM <DIR> ..
06/20/2008 02:50 PM 10,240 VIDEO_TS.BUP
06/20/2008 02:50 PM 10,240 VIDEO_TS.IFO
06/20/2008 03:08 PM 147,456 VTS_01_0.BUP
06/20/2008 02:50 PM 147,456 VTS_01_0.IFO
06/20/2008 02:50 PM 87,863,296 VTS_01_0.VOB
06/20/2008 02:53 PM 1,073,739,776 VTS_01_1.VOB
06/20/2008 02:57 PM 1,073,739,776 VTS_01_2.VOB
06/20/2008 02:59 PM 1,073,739,776 VTS_01_3.VOB
06/20/2008 03:00 PM 903,088,128 VTS_01_4.VOB
06/20/2008 03:02 PM 1,073,739,776 VTS_01_5.VOB
06/20/2008 03:04 PM 1,073,739,776 VTS_01_6.VOB
06/20/2008 03:06 PM 1,073,739,776 VTS_01_7.VOB
06/20/2008 03:08 PM 784,902,144 VTS_01_8.VOB
13 File(s) 8,218,607,616 bytes
2 Dir(s) 40,520,073,216 bytes free
Hi,
I think you may have to reinstall the program but use a different folder rather than c:\Program Files (x86). Due to Vista the application can't write in that folder and so the Log file can't be created.
C.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I am getting the same error. Anything under 1gig is ok but large vob files will not convert
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title:
Version: 2.5.0.0
Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe
Executable size: 460 KB
Executable size in bytes: 471040
Executable CreationTime: 1/1/2000 12:00:00 AM
Executable LastWriteTime: 1/1/2000 12:00:00 AM
Executable LastAccessTime: 1/1/2000 12:00:00 AM
****************************** Drives *******************************
**********************UNABLE TO GET SYSTEM INFO*******************
********************** Input Folder *******************
15:26:18: Volume in drive C has no label.
15:26:18: Not enough storage is available to process this command.
15:26:18: Directory of C:\Users\Shaun\Test_Videos\The_Smiths
15:26:18: 07/24/2008 09:07 AM <DIR> .
15:26:18: 07/24/2008 09:07 AM <DIR> ..
15:26:18: 07/22/2008 07:46 PM 6,144 VIDEO_TS.BUP
15:26:18: 07/22/2008 07:46 PM 6,144 VIDEO_TS.IFO
15:26:18: 07/22/2008 07:46 PM 36,864 VTS_01_0.BUP
15:26:18: 07/22/2008 07:46 PM 36,864 VTS_01_0.IFO
15:26:18: 07/22/2008 07:46 PM 3,375,077,376 VTS_01_1.VOB
15:26:18: 5 File(s) 3,375,163,392 bytes
15:26:18: 2 Dir(s) 209,741,529,088 bytes free
15:26:18: C:\Users\Shaun\Test_Videos\The_Smiths>
********************** AV Details *******************
file=C:\Users\Shaun\Test_Videos\The_Smiths\VTS_01_ 1.VOB
FormatName=mpeg
Num_Frames=84628
DurationInSecs=2823
Duration=00:47:03.7
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=720
Height=480
Standard=NTSC
BitRate=9561
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0xa0]
Audio1SampleRate=48000
Audio1Codec=pcm_s16be
Audio1BitRate=192
Audio1Channels=2
************************ END ************************
15:26:19: FFmpeg version HEAD, Copyright (c) 2000-2004 Fabrice Bellard
15:26:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
15:26:19: libavutil version: 49.0.0
15:26:19: libavcodec version: 51.9.0
15:26:19: libavformat version: 50.4.0
15:26:19: built on Jun 20 2006 11:22:30, gcc: 3.4.4 (mingw special)
15:26:19: Input #0, mpeg, from 'multi:C:\Users\Shaun\Test_Videos\The_Smiths\VTS_0 1_1.VOB*':
15:26:19: Duration: N/A, bitrate: N/A
15:26:19: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9801 kb/s
15:26:19: Stream #0.1[0xa0]: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
15:26:19: Assuming NTSC for target.
15:26:19: Output #0, dvd, to 'C:\Users\Shaun\Desktop\VTS_01.mpg':
15:26:19: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9801 kb/s
15:26:19: Stream #0.1: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
15:26:19: Stream mapping:
15:26:19: Stream #0.0 -> #0.0
15:26:19: Stream #0.1 -> #0.1
15:26:19: frame= 0 q=-1.0 Lsize= 0kB time=10000000000.0 bitrate= 0.0kbits/s
15:26:19: video:0kB audio:0kB global headers:0kB muxing overhead -1.#IND00%
********************** Output Folder *******************
15:26:19: Volume in drive C has no label.
15:26:19: Not enough storage is available to process this command.
15:26:19: Directory of C:\Users\Shaun\Desktop
15:26:19: 07/24/2008 03:26 PM <DIR> .
15:26:19: 07/24/2008 03:26 PM <DIR> ..
15:26:19: 07/22/2008 03:08 PM 839 Any Video Converter.lnk
15:26:19: 04/24/2008 08:42 PM 794 DVD Shrink 3.2.lnk
15:26:19: 06/27/2008 08:24 AM 742 DVDFab 5.lnk
15:26:19: 07/23/2008 03:55 PM 818 Handbrake.lnk
15:26:19: 04/30/2008 07:33 PM 484 Invoices.lnk
15:26:19: 07/20/2008 07:25 PM 1,704 LimeWire 4.18.3.lnk
15:26:19: 07/24/2008 02:56 PM 2,165 TVersity.lnk
15:26:19: 07/24/2008 03:26 PM 0 VTS_01.mpg
15:26:19: 04/21/2008 07:57 PM 905 Yodm3D - Shortcut.lnk
15:26:19: 9 File(s) 8,451 bytes
15:26:19: 2 Dir(s) 209,742,512,128 bytes free
15:26:19: C:\Users\Shaun\Desktop>
VOB2MPG Batch Processing
By jonj1611 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Aug 2011, 13:35 -
VOB2MPG Problem - MPG Duration Appears Incorrect
By ScottJ in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 25th Dec 2009, 20:15 -
finished processing with no files
By l4l4u in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 15th Oct 2009, 02:35 -
VOB2MPG-Pro Finished processing 0 vobsets
By jay782 in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 4th Oct 2009, 02:10 -
VOB2MPG v3.0 PRO mpg without duration
By donzella in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 9th Sep 2009, 14:51
Statistics
Newest guides
Latest tool updates
New media comments
