VideoHelp.com Forum
    Hey everyone,
    I am using an NVidia 8600GT video card to run a Dell 2407WFPHC and a Dell 1707FP. The program Media Player Classic will not display video when on my second monitor. It plays the audio, but displays a black screen instead of the video. If I move the MPC window to my primary screen, the video is there just fine.
    I am using the most up to date drivers from nvidia and win xp sp3.
    About a week ago I had to do a system restore from a Norton Ghost Image. Before the restore, the video played back fine on both screens.
    Please help me fix this. Thanks for any help.
    Fiddle the video overlay settings. These are in the "Video and Television" section of the NVIDIA Control Panel.
    Thanks for the quick reply jagabo, but that isn't going to do it. (unless you can point to something more specific in that setting window).
    However, I have played around with the output settings in MPC and using VMR9 (renderless) has allowed me to have seemless vidoe playback as before.
    So I guess I solved it for myself. I hope it helps others as well.
    But does anyone know why the default in MPC doesn't allow this to work?
    Thanks again.
    It's not MPC's fault. Your Video Overlay isn't working correctly. It's very common with newly installed or upgraded video drivers for the video overlay settings to be screwed up. You can sometimes fix it simply by adjusting the overlay settings.
    Also try disabling hardware acceleration and then re-enabling it from Display Properties -> Settings -> Advanced -> Troubleshoot -> Hardware Acceleration. Turn it all the way down, Apply, then turn it back up and Apply. Doing this often fixes whatever went wrong during the installation/upgrade.
  1. MPC won't display on secondary monitor
    By Monarch1st in forum Software Playing
    Last Post: 17th Feb 2012, 12:11
  2. MPC - Subtitles won't display on secondary device, VMR7/9
    By John_Jordan in forum Software Playing
    Last Post: 12th May 2009, 08:57
  3. Replies: 7
    Last Post: 22nd Sep 2008, 15:44
  4. Computer Back on from Sleep Mode, But Monitor Won't Display
    By kerrex_2006 in forum Newbie / General discussions
    Last Post: 20th Mar 2008, 14:58
  5. Replies: 2
    Last Post: 24th May 2007, 13:28
