Hi, I'm a newbie to AV applications software and I was experimenting with trying to rip a DVD recorded from TV so that I couild edit it. I used Nero Recode but it didn't appear to be working. I've now uninstalled Nero and downloaded a number of other freeware applications for decoding, authoring et al.
However, it also appears that Recode worked because I've discovered an AVI file of the programme in a folder in My Documents. But, when I try to open it it tells me that it requires 'vids:XVID' decompressor. Is this a codec I can download or part of the now deleted Nero?
Thanks, Ian
Xvid codec. Also found in ffdshow, and Divx codec.
Hi jagabo, thanks for the really quick response. Once I've downloaded either of these will a media player, e.g. Windows Media player automatically detect the codec or is there something else I have to do, such as locate the codec and put into a folder?
Yes. I'm pretty sure both Divx and ffdshow default to decoding Xvid. If not, all you have to go is go into their setup applets and enable it.Originally Posted by iansport
Thanks again, I've just downloaded and will have a good read of the help files tomorrow!
I recommend you download and install the Xvid codec. That will be simplest.
Hi Jagabo, thanks for the link to the codec. I'd already downloaded ffdshow and as you thought media players will use this application and its codecs. I checked Wikipedia for some more info on it and I'll do some experimentation and learn about configuring it. If I'm struggling I'll just download the codec.
Thanks, Ian
"vids:divx decompressor"
By shernoam in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2005, 09:29 -
vids: 'mpg4' decompressor???
By tzoid in forum Video ConversionReplies: 1Last Post: 19th Jun 2002, 13:04 -
Video no available, cannot find "vids:divx" decompressor????
By Nugrl in forum Video ConversionReplies: 5Last Post: 12th Dec 2001, 04:11 -
vids:MP34 decompressor error ?????
By mol3000 in forum Video ConversionReplies: 5Last Post: 13th Nov 2001, 06:15 -
vids:MP34 decompressor error !?!?!?!?!?!?!??!?!?!
By mol3000 in forum Software PlayingReplies: 7Last Post: 10th Nov 2001, 15:02
Newest guidesLatest tool updatesNew media commentsSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
