im trying to convert .rmvb to .avi and it has been an aggravating evening to say the least -.- ..... i finally got the ffmpegx to stop freezing everytime i dropped a .rmvb file into, then i got past the progress.app thing, now when it allows me to click encode, the encode progress skips right to finished and there is no output file to be found. anyone know how i can be helped?
also if its any help, this is what the progress info is:
Encoding started on Thu Jun 19 02:29:03 PDT 2008
FIXME:Hardenabling SSE and SSE2 without detection
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
CPU: Intel (Family: 6, Stepping: 6)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x4fc217c
REAL file format detected.
Try renaming foo.rmvb to foo.rm, in the hope that the info shows more than those 9 lines.
that solved it thnx
I have everything installed perfectly, i think, but every time i try to convert a .rmvb file, or .rm, it skips frames when converting.. Any idea to stop skipping frames?
If the [Play] button in ffmpegX plays a Real Media file, then reallib and mplayer were installed correctly.Originally Posted by wolfgames
Does the log show the Skipping Frame message or do you notice missing frames in the output? The first happens often and don't have to point to a problem, the latter might point to a framerate conversion that perhaps wasn't intended.Originally Posted by wolfgames
It just says Skipping Frame in the Info thing. But when i watched it after its done converting, i didnt see any skipped frames so it was fine. but thank you
how did you get it to stop freezing when you drop video? thanks
video (avi) playback skips and stutters in all players in windows xp
By ericgregory in forum Software PlayingReplies: 12Last Post: 28th Jul 2010, 16:01 -
RMVB to AVI using VirtualDubMod
By mahdlo in forum Video ConversionReplies: 3Last Post: 25th Oct 2009, 00:36 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 10:29 -
Finished my WMM project, saved as avi file-7.35gb. Now what?
By jbitakis in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2008, 12:27 -
help with rmvb to avi?
By fruitpassion in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 17:46
