Ok, I am kindof a newbie, I used to be really uptodate with everything about 3 years back but lost interest for a while and am back trying to figure something out,
Problem: I am trying to burn a file to dvd using adobe encore, it is already an mpeg file which was taken from a non copyrighted dvd, I used magic dvd ripper to take it from dvd to mpeg, well I can play the files in windows media player and view the files in multiple programs, except adobe premier cs3 and encore, I used video inspector which shows I have the codecs(already knew that), but when I try to open it in a adobe product it does not import correctly sometimes I get nothing, othertimes I get a long green footage with the original audio, video inspector says it is an incomplete file, I am not sure if it is the same as open gop or not. but I suspect that this is why adobe will not read it, but again I am not sure,
Goal: I would like to fix the file without having to re-render the file, why? becuase their are lots of file and I do not have time to re-render all of them, and I do not want to lose original quality, I tried a couple of file fix programs to no avail, it seems as though it has done nothing to the file.
What can I do to fix this?
Thread: Mpeg Problems
Try instead vob2mpg or pgcdemux and split to video and audio streams and import in adobe encore.
If that wont help then post the video details from the vob/mpg using mediainfo. -
Great Thanks,
I will try that as soon as I can, the only problem is the dvds are in north carolina, and I am in utah, I will be able to get them again in about 2-3 weeks, does anyone know of any solutions without ripping again I would really appreciate it, if not I guess I will just have to get them back again
Thanks -
Sorry, almost forgot here is the media info, if this helps clarify, the file is only 45 minutes long, but mediainfo says 13hrs
General
Complete name : C:\Users\Travis\Desktop\TITLE03.mpg
Format : AC-3
Format/Info : Audio Coding 3
File size : 1.10 GiB
Duration : 13h 39mn
Overal bit rate : 192 Kbps
Audio
Format : AC-3
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz -
if you have dvdlab it can re-write the gop timecodes after a demux and then you could re-author it to a new dvd. or you can try restream an check the box to reset timestamps, but you may have to de-mux it first to .m2v as for encore it probably doesn't like the ac-3 audio. again de-mux it and encore will accept the .m2v video only stream.
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 16:39 -
MPEG-2 Problems...
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 13:14 -
Mpeg Layer 3 problems
By ada1984 in forum EditingReplies: 7Last Post: 8th Nov 2007, 21:30 -
MPEG 2 problems
By specwarrior09 in forum CapturingReplies: 5Last Post: 26th Aug 2007, 12:16 -
Problems converting HD Mpeg
By fearmyrage in forum Video ConversionReplies: 3Last Post: 7th Jun 2007, 22:46
