  1. Preservationist davideck's Avatar
    I am looking for a DVD Recorder with a DV Input that is compatible with the Canon HV30 1394 port in "DV Locked" mode in order to quickly author SD DVDs of HD content. I would prefer a unit that automatically sets chapter points "By Scene" or "By Date". The Toshiba KX50 has this functionality but does not recognize the HV30. Any suggestions?
    Life is better when you focus on the signals instead of the noise.
    I wonder how the Philips 3575 would react, seeing how it supports HD source downconversion to DVD.
    Only one person has reported using the 3575/76 with a Canon Elura DV camera. It copied WS material fine, but as we know, the 3575/76 doesn't set the WS flag for playing WS on a 4:3 TV... his only "complaint."
    I don't have a DV camera so don't know much more than that, but here's a post on recording WS with a ref. to someone else who did record WS via DV input with a diff. camera
    The 3575/76 sets auto and custom chapter marks, but the auto are per a user-selected interval. More on Chapter Marks towards bottom of this page.
    I'm using TDA3 to re-author to menu-less 16:9. Even if I did 352x480 LP mode 16:9, I use the flag and it's playing fine all over the house. Not compliant, but seems fine.
    I have it connected to HDTV anyway, so I usually don't care, I keep little off the hard drive, it's mostly my PVR.
    Mostly keep 4:3 old tv shows if I do.
  5. Preservationist davideck's Avatar
    If I do an SD digital dub via 1394 from the HV30 to my JVC MiniDV Camcorder, then I can transfer to the KX50 via 1394 from the JVC. However, I have found that chapter points are only added in SD recordings. The scene breaks in HD recordings do not make it through for some reason...
  1. Cannot capture HDV with Canon HV30
    By ChrisU in forum Capturing
    Last Post: 25th Oct 2010, 01:40
  2. create DVD in premiere pro from canon HV30
    By yunakokimama in forum Authoring (DVD)
    Last Post: 22nd Jul 2009, 21:02
  3. canon hv30 to cimputer
    By gilgeva1 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Apr 2009, 12:54
  4. canon hv40 vs hv30/20
    By minidv2dvd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Feb 2009, 14:25
  5. Canon HV20/HV30
    By Tyler2000 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 31st May 2008, 14:43
About   Advertise   Forum   RSS Feeds   Statistics   Tools
