Hi,
I'm currently in the process of editing a video, so that I can place some new text over the original text. Does anyone know how I would go about doing this?
Thread: Adding text over original text
What are you editing with ? Most editors have a title or text overlay function.
You have two basic options. You can attempt to remove the original text using one of the delogo filters for virtualdub. Most likely you will end up with a blurred area on your image which you can then put the new text over. Or you can put a black box over the original text, with the next text on top of this.
However without knowing what tools you are using it is impossible to give you anything specific.
Ah, silly me... I'm using Pinnacle 8. There is a title option but I can't seem to work out how to add the text into the video. I don't mind putting a black box over the text to be honest
http://www2.gol.com/users/spee/Studio/titles.htm is very sparse but hints that the overlay option is what you need to use. The rest you will have to read the help files or manual for.
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
Adding text to video....
By pinetop in forum Newbie / General discussionsReplies: 10Last Post: 17th Nov 2009, 17:55 -
adding text to a video
By Grunta in forum EditingReplies: 0Last Post: 6th Feb 2009, 21:09 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
Statistics
Newest guides
Latest tool updates
New media comments
