VideoHelp.com Forum
    HI i have this external burner it can read a movie..but it doen't recognize a dvd+r ,,and have plenty of these.
    i read in other post that this is a lite on...
    -everytime i load a +R it makes a sound like grasping th drive then the error message
    --------is there anyway i can fix this problem..btw firmware is updated to BYX5 FROM SONY
    ....can i use lite one firmware to fix this issue?
    it can read a dvd+R written already,,like a movie already burnt..
    i'm using verbatim+
  2. Member Krispy Kritter's Avatar
    Issues like this are typically one of three basic things. 1) firmware is out of date 2) media issues 3) faulty hardware
    Since you have the latest firmware, you are down to media and hardware. Although you are using good media already, it's possible you have a bad batch or simply that the Sony doesn't like that brand/type. It's easy enough to try different media. Aside from that, you may just have a faulty burner.
    Google is your Friend
    krispy,,thanks for the advice,,,
    what i know for sure,,is that no more sony burners..
    thanks
  4. DVD Ninja budz's Avatar
    This thread should be moved to the DVD REWRITER section.
    SONY doesn't manufacture their dvd burners anymore. SONY is infamous for not providing updated firmware to match newer media id's.
    You can try crossflashing your drive to the LITEON firmware. IMHO it sounds like your drive is dying. Buy a new one since they're inexpensive these days.
  1. Windows 7 doesnt recognize jvc gr-d796u camcorder
    By ot5707 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 15th Jan 2012, 02:27
  2. Replies: 3
    Last Post: 21st Jun 2011, 12:30
  3. 5982 doesnt recognize correct SRT file
    By chits007 in forum DVD & Blu-ray Players
    Last Post: 31st Mar 2008, 23:30
  4. XP Pro doesnt recognize USB flash drive
    By rubberman in forum Computer
    Last Post: 9th Dec 2007, 10:20
  5. Newbie that doesnt know much and doesnt know where to put her query.
    By emilymeg in forum Newbie / General discussions
    Last Post: 10th Jun 2007, 12:46
