Can anyone share the proper settings for encoding an avi file so it can be burned to dvd using either Popcorn 2 or Toast 6 Lite?
I've tried encoding using the typical avi to dvd ffmpeg without the authoring checked (to generate a VIDEO_TS folder) and with that option checked. No luck either time.
This particular avi file has a subtitle crt file imported but I have a couple of other avis without subtitles that I'd like to encode to dvd as well.
I'm using a Mac G3 with OS X 10.4 and eighty GB of storage.
Thanks for any help.
Beside the authoring checkbox, there are some other variations in encoding to DVD with ffmpegX.
If you encode with the DVD mpeg2enc preset, then it is set default to using Altivec (Options tab), which should be disabled when using a G3 Mac.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
ffmpegX and/or Toast 8 - Loss of video quality in converting to DVD
By bonespur in forum MacReplies: 2Last Post: 9th Mar 2011, 01:52 -
Do you prefer fresh popped popcorn or day old popcorn?
By yoda313 in forum PollsReplies: 20Last Post: 14th Jul 2009, 22:16 -
Newbie Question about Avi's, ffmpegx and Toast
By pmmassacre in forum ffmpegX general discussionReplies: 12Last Post: 25th Apr 2009, 23:38 -
Popcorn 3 leapfrogs some Toast video features
By Frobozz in forum MacReplies: 7Last Post: 17th Mar 2008, 12:27
Statistics
Newest guides
Latest tool updates
New media comments
